                Easy to useConnect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet.
                Carry and store with your devicePack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it.
- HP USB-C LC - power adapter - 65 Watt
- Power adapter - external
- Localisation
- English / United Kingdom
- Input Voltage
- AC
- Power Capacity
- 65 Watt
- Designed For
- Pro c640 G2 Chromebook; ProBook 635 Aero G7 Notebook
- Localisation
- Input Voltage
- AC
- Power Capacity
- 65 Watt
- Designed For
- HP Pro c640 G2 Chromebook , HP ProBook 635 Aero G7 Notebook
