Easy to use
Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet. -
Carry and store with your device
Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it.
- HP USB-C LC - power adapter - 65 Watt
- Power adapter - external
- Localisation
- English / United Kingdom
- Input Voltage
- AC
- Power Capacity
- 65 Watt
- Designed For
- HP t430 v2; Chromebox Enterprise G3; Fortis 11 G9; Presence Small Space Solution Plus AI Camera with Microsoft Teams Rooms, Small Space Solution Plus AI Camera with Zoom Rooms, Small Space Solution with Microsoft Teams Rooms, Small Space Solution with Zoom Rooms; Pro c640 G2; Pro x360; ProBook 635
- Localisation
- Input Voltage
- AC
- Power Capacity
- 65 Watt
- Designed For
- HP t430 v2 , HP Chromebox Enterprise G3 , HP Fortis 11 G9 Q Chromebook , HP Presence Small Space Solution Plus AI Camera with Microsoft Teams Rooms, Small Space Solution Plus AI Camera with Zoom Rooms, Small Space Solution with Microsoft Teams Rooms, Small Space Solution with Zoom Rooms , HP Pro c640 G2 Chromebook , HP Pro x360 Fortis 11 G9 Notebook , HP ProBook 635 Aero G7 Notebook
