HP USB-C Docking Station
Quicklinx: DL86WS00 Mfr#: 3FF69AA#ABU
Maximize productivity in the office with one USB-C cable connection to the enterprise-ready HP USB-C Dock G4. It delivers device charging to your HP notebook, supports up to three displays, and enables connectivity to your wired network and accessories.
  • Multi-task like a pro
    Connect the dock's cable to your device's USB-C port to charge it while you work, access your wired network, and connect to one 4K or up to three WSXGA+ displays, plus your accessories, through two DisplayPort , HDMI, RJ-45, and five USB ports.
  • Enterprise-grade manageability
    Experience advanced network manageability with PXE boot, Wake on LAN, and MAC Address Pass Through support, even when the system is On or in Sleep, Hibernate or Off states, and 802.1x authentication.
  • Secure inside and out
    Get optimal security with a driver-free dock that has no internal flash memory, and can be physically locked down with a lock slot and your choice of locks.
  • Power for plenty of devices
    Charge all of your HP devices, from detachables to notebooks, with one dock that supports six power profiles, from 5V to 20V. Use the power button on the front of the dock to turn on your docked notebook while its lid is closed.
  • World-class support
    Rest easy with a one-year limited warranty.
HP USB-C Dock G4 - docking station - USB-C - 1GbE
Docking station
Docking Interface
USB-C
19.8 cm x 6.9 cm x 2.2 cm
355 g
English / United Kingdom
Gigabit Ethernet
Power adapter 90 Watt Power Provided
1-year warranty
Docking station
19.8 cm
6.9 cm
2.2 cm
355 g
Gigabit Ethernet
1 x PoweredUSB 3.0 , 1 x USB-C (power port) , 1 x audio , 1 x SuperSpeed USB 3.0 , 2 x USB 2.0 , 1 x network , USB-C , 2 x display / video - DisplayPort , 1 x display / video - HDMI
1 x power cable , 1 x power adapter , 1 x USB-C cable - 1 m
Preboot Execution Environment (PXE) support, wake on LAN, MAC address pass-through, security lock slot (cable lock sold separately)
Security Slot Type
Kensington security slot
Power adapter
Power Provided
90 Watt
Windows 10, Windows 10 Mobile
Limited warranty - 1 year
