HP USB Business Speakers V2
Quicklinx: CYRLWS00 Mfr#: N3R89AA
Quickly and easily add stereo sound to your workspace with HP USB Business Speakers v2, a set of stylish desktop speakers powered by your PC's USB port.
  • Simple setup
    Connect the included cables to any USB port and headphone or lineout port on your PC, then position the speakers wherever you need them.
  • Intuitive features
    Turn the speakers on and adjust the volume with a conveniently-located top knob on the right speaker. The white LED confirms power.
  • Supported by HP
    Rest easy with a one-year limited warranty.
HP USB Business speakers v2 - speakers - for PC
Speakers - for PC
System Components
2 speakers
Speaker Type
Active
Nominal Output Power (Total)
4 Watt
Audio System Max Output Power
4.6 Watt
Frequency Response
200 - 20000 Hz
Amplifier
Integrated
Speaker System Details
2 x speaker 2 Watt - 200 - 20000 Hz - 4 Ohm
Power Options
USB powered
6.95 cm x 8.95 cm x 17 cm
550 g
1-year warranty
HP 260 G2, 260 G3, 280 G3, 290 G1; Desktop Pro A G2; EliteDesk 705 G1, 705 G3, 705 G4, 800 G2, 800 G4, 800 G5; ProDesk 400 G1, 400 G2, 400 G2.5, 400 G3, 400 G4, 400 G5, 400 G6, 405 G1, 405 G2, 405 G4, 490 G3, 600 G1, 600 G3, 600 G4; Workstation Z1 G5 Entry
Speakers - for PC
Enclosure Colour
Grille Colour
Speaker System
System Components
2 speakers
Speaker Type
Active
4 Watt
Max (RMS) Output Power (Total)
4.6 Watt
Frequency Response
200 - 20000 Hz
Amplifier
Integrated
Controls
Power on/off, volume
Speakers Included
2 x speaker - 2 Watt - 200 - 20000 Hz - 4 Ohm - wired
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Software kit
Power Source
USB
Options
USB powered
6.95 cm
8.95 cm
17 cm
550 g
Limited warranty - 1 year
HP 260 G2, 260 G3, 280 G3, 290 G1 , HP Desktop Pro A G2 , HP EliteDesk 705 G1, 705 G3, 705 G4, 800 G2, 800 G4, 800 G5 , HP ProDesk 400 G1, 400 G2, 400 G2.5, 400 G3, 400 G4, 400 G5, 400 G6, 405 G1, 405 G2, 405 G4, 490 G3, 600 G1, 600 G3, 600 G4 , HP Workstation Z1 G5 Entry
