hp USB 2-Button Optical Mouse 7F
HP USB 2-Button Optical Scroll Mouse
Quicklinx: 3BHNWS00 Mfr#: DC172B
Two-button mouse with scroll wheel that provides the speed and accuracy of optical tracking in a simple, elegant design. Has no ball or moving parts, which improves its durability, makes it require less cleaning, and eliminates sticking.
HP DC172B - mouse - USB
Mouse
Wired - USB
6.3 cm x 11.6 cm x 3.8 cm
120 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
1 x USB cable - integrated - 1.85 m
Microsoft Windows 95/98, Microsoft Windows Millennium Edition, Microsoft Windows 2000 / XP
1-year warranty
Mouse
6.3 cm
11.6 cm
3.8 cm
120 g
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
Limited warranty - replacement - 1 year
