Unlock new possibilities with the HP Universal USB-C Multiport hub, now supporting any USB-C compatible PC. 7 ports, 1 power and data passthrough cable, and many peripherals to plug and play however you like. It also supports dual 4K displays via HDMI 2.0 and 1 DisplayPort 1.2. This hub is all you need to stay connected.
Designed to Travel
Slim and sleek design is portable for you to take on the go. -
System Manageability
Easily manage a wide range of notebooks remotely via HP's advanced built-in PC network manageability features. -
Connect & Power Your PC
Keep your PC charged via the USB-C passthrough while powering up or connecting data through the 7 total ports.
- HP Universal USB-C Multiport Hub - docking station - USB-C - HDMI, DP
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- HDMI, DP
- 15 cm x 5.5 cm x 2.15 cm
- 115 g
- 1-year warranty
- Product Type
- Docking station
- 15 cm
- 5.5 cm
- 2.15 cm
- 115 g
Video
- Max Resolution Details
- 4K - 60 Hz (Single Display) , 4K - 30 Hz (Dual Display)
- 2 x USB 3.2 Gen 1 , 1 x USB-C 3.2 Gen 1 , 1 x display / video - HDMI , 1 x display / video - DisplayPort , 1 x network - Ethernet - RJ-45 , 1 x USB-C (power port)
- Wake on LAN, firmware upgradable, Preboot Execution Environment (PXE) support, MAC address pass-through
- OS Required
- Apple MacOS, Google Chrome OS, Microsoft Windows 10 / 11
- Limited warranty - 1 year
