Adding a second screen to your notebook just got radically simpler with the lightweight HP U160 39,6 cm (15.6') LED Backlit Monitor. Increase your productivity with a portable companion display that quickly opens into its own tilt-adjustable stand and easily connects to your notebook with one USB cable. Share presentations across a table or desk wherever you work. The adjustable stand quickly converts back into a carrying case so you can stow and go.
Increase productivity with a companion display for your notebook
The super light and thin HP U160 companion display sets up and folds down in a snap, and connects to any notebook with a USB 2.0 port.Ample 39,6 cm (15.6') diagonal screen size, 16:9 widescreen aspect ratio, contrast ratio, and brightness aligns with most traditional notebook screens-without the weight and bulk of carrying a second notebook. -
Designed for easy portability
The integrated flip & fold case deploys the monitor quickly, doubles as a stand, and helps protect the display while stored.Lightweight and thin, the modern design slides easily into your notebook carrying case right beside your notebook so you can take it with you wherever you work.The included USB cord stores easily into a built-in pocket on the case for quick accessibility. -
Ideal for on-the-go presentations
Expand your screen real-estate so you can show and share presentations without crowding around a single notebook screen.Easy setup doesn't require a second power cord-get up and running quickly with the single USB cord (included) and work at a desk in the office or in a hotel room, restaurant, lobby, or public meeting space. -
Earn your environmental stripes
The intelligent, energy-efficient design is built with the environment in mind to help you reduce power consumption.Mercury-Free LED backlighting, BFR/PVC-free design, arsenic-free display glass and recyclable packaging are just a few of the environmentally conscious details built into the display. -
Peace of mind, with HP
HP protection includes a 3-year parts, labor, and onsite service standard limited warranty.Select optional HP Care Pack Services to extend service contracts beyond the standard warranties.
- HP U160 - LED monitor - 15.6" - Smart Buy
- LED-backlit LCD monitor - 15.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.252 mm
- Brightness
- 180 cd/m²
- Contrast Ratio
- 500:1
- Response Time
- 12 ms
- Colour Support
- 262,144 colours
- Colour Gamut
- 60%
- Input Connectors
- USB
- Tilt
- Screen Coating
- Anti-glare
- Black
- 37.7 cm x 2.6 cm x 27.85 cm
- 1.54 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VCCI, C-Tick, BSMI, GOST, cUL, SABS, SASO, CB, CCC, PSB, FCC, C-ETL, RoHS, IEC 60950-1, KCC, WEEE, Green Mark, ICES, S Mark, TUV Bauart, KC, CECP, CEL, Nordic Ecolabel, GOST-R 50377-1992, NOM-019-SCFI-1998
- Display Type
- Diagonal Size
- 15.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.252 mm
- Brightness
- 180 cd/m²
- Contrast Ratio
- 500:1
- Colour Support
- 262,144 colours
- Colour Gamut
- 60%
- Response Time
- 12 ms
- Vertical Refresh Rate
- 60 Hz
- Horizontal Refresh Rate
- 47.712 kHz
- Video Bandwidth
- 76.4 MHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- Black
- 37.7 cm x 2.6 cm x 27.85 cm - with stand
- 1.54 kg
- USB 2.0
Mechanical
- Tilt
- Tilt Angle
- +15/+45
- Cables Included
- 1 x USB power splitter cable - 1.5 m
- Backlight Life
- 15,000 hours
- Localisation
- HP Smart Buy
- Power Consumption (Typical)
- 5 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows 7 Professional (32/64 bits)
- Dimensions & Weight Details
- With stand - width: 37.7 cm - depth: 2.6 cm - height: 27.85 cm - weight: 1.54 kg , Without stand - width: 37.5 cm - depth: 1.45 cm - height: 27.13 cm
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
