Boost your security, productivity, and connectivity with this Thunderbolt 4 dock. It protects your network and devices from the moment you log in, supports multi-OS compatibility, and can support up to four 4K displays. Ideal for ITDMs and hybrid workers, this dock also makes home or office device management easy.
Modern Device Manageability
With Intel vPro Active Management Technology, authorized administrators can remotely access notebooks using wired connections, even if turned off, to make updates. -
Electronic Asset Management for Your Docks
Empower your IT to manage and track your docks by product name, serial number, and MAC Address from anywhere with the time-saving, easy-to-use Electronic Tag (eTag) asset management tool. -
Thoughtful Product Packaging
HP is committed to reducing plastic in landfills by using recyclable, fiber-based, and sustainably sourced packaging that meets recycling requirements, so it can stay out of the landfill when customers are finished with it. -
One Cable. Two Power Options
With two power options (120W/280W) from one cable, you can power mainstream and high performance PCs alike with just one cable/dock. -
We Test So You Can Rest
Rigorous testing helps assure dock compatibility across select HP notebooks and select Apple , Dell, and Lenovo notebooks with USB-C power ports. -
More Ports. More Flexibility
More ports means more capabilities. With a TB4 , HDMI, two USB-C , two DisplayPorts , four USB-A 3.2 ports and an RJ45 port, you can connect multiple devices like a keyboard and mouse.
- HP Thunderbolt Dock G4 - docking station - USB-C / Thunderbolt 4 - 2 x DP, Thunderbolt, USB-C, HDMI - 1GbE, 2.5GbE
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- Bundled with
- Combo cable
- 9.8 cm x 9.8 cm x 6.8 cm
- 760 g
- Localisation
- English / United Kingdom
- Networking
- Gigabit Ethernet, 2.5 Gigabit Ethernet
- Power
- Power adapter AC 100-240 V (50/60 Hz) 280 Watt Power Provided
- 1-year warranty
- Product Type
- Docking station
- Bundled with
- Combo cable
- 9.8 cm
- 9.8 cm
- 6.8 cm
- 760 g
- Localisation
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
- 4 x USB 3.2 Gen 1 , 1 x USB-C 3.2 Gen 2 , 1 x Thunderbolt 4 , 1 x network - 2.5GBase-T - RJ-45 , 1 x USB-C / DisplayPort , 1 x audio / video - HDMI - 19 pin HDMI Type A , 2 x audio / video - DisplayPort - 20 pin DisplayPort
- Cables Included
- 1 x Thunderbolt 4 cable - 80 cm
- Security lock slot (cable lock sold separately), wired vPRO, wireless vPro, wake on LAN, Preboot Execution Environment (PXE) support, MAC address pass-through
- Security Slot Type
- Kensington security slot
- Power Device
- Power adapter
- Voltage Required
- AC 100-240 V (50/60 Hz)
- Power Provided
- 280 Watt
- OS Required
- Apple MacOS, Google Chrome OS, Microsoft Windows 10 / 11
- Limited warranty - 1 year
- Shipping Width
- 27.5 cm
- Shipping Depth
- 14.3 cm
- Shipping Height
- 14.85 cm
- 0 °C
- 35 °C
