HP Thunderbolt Dock G4 - USB-C / Thunderbolt 4 - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE
Quicklinx: H57SWS00 Mfr#: 4J0G4AA#ABU
£193.84 ex VAT
£232.60 inc VAT
Boost your security, productivity, and connectivity with this Thunderbolt 4 dock. It protects your network and devices from the moment you log in, supports multi-OS compatibility, and can support up to four 4K displays. Ideal for ITDMs and hybrid workers, this dock also makes home or office device management easy.
  • Modern Device Manageability
    With Intel vPro Active Management Technology, authorized administrators can remotely access notebooks using wired connections, even if turned off, to make updates.
  • Electronic Asset Management for Your Docks
    Empower your IT to manage and track your docks by product name, serial number, and MAC Address from anywhere with the time-saving, easy-to-use Electronic Tag (eTag) asset management tool.
  • Thoughtful Product Packaging
    HP is committed to reducing plastic in landfills by using recyclable, fiber-based, and sustainably sourced packaging that meets recycling requirements, so it can stay out of the landfill when customers are finished with it.
  • One Cable. Two Power Options
    With two power options (120W/280W) from one cable, you can power mainstream and high performance PCs alike with just one cable/dock.
  • We Test So You Can Rest
    Rigorous testing helps assure dock compatibility across select HP notebooks and select Apple , Dell, and Lenovo notebooks with USB-C power ports.
  • More Ports. More Flexibility
    More ports means more capabilities. With a TB4 , HDMI, two USB-C , two DisplayPorts , four USB-A 3.2 ports and an RJ45 port, you can connect multiple devices like a keyboard and mouse.
HP Thunderbolt Dock G4 - docking station - USB-C / Thunderbolt 4 - 2 x DP, Thunderbolt, USB-C, HDMI - 1GbE, 2.5GbE
Docking station
Docking Interface
Video Interfaces
Bundled with
Combo cable
9.8 cm x 9.8 cm x 6.8 cm
760 g
English / United Kingdom
Gigabit Ethernet, 2.5 Gigabit Ethernet
Power adapter AC 100-240 V (50/60 Hz) 280 Watt Power Provided
1-year warranty
Docking station
Bundled with
Combo cable
9.8 cm
9.8 cm
6.8 cm
760 g
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
4 x USB 3.2 Gen 1 , 1 x USB-C 3.2 Gen 2 , 1 x Thunderbolt 4 , 1 x network - 2.5GBase-T - RJ-45 , 1 x USB-C / DisplayPort , 1 x audio / video - HDMI - 19 pin HDMI Type A , 2 x audio / video - DisplayPort - 20 pin DisplayPort
1 x Thunderbolt 4 cable - 80 cm
Security lock slot (cable lock sold separately), wired vPRO, wireless vPro, wake on LAN, Preboot Execution Environment (PXE) support, MAC address pass-through
Security Slot Type
Kensington security slot
Power adapter
Power Provided
280 Watt
Apple MacOS, Google Chrome OS, Microsoft Windows 10 / 11
Limited warranty - 1 year
Shipping Width
27.5 cm
Shipping Depth
14.3 cm
Shipping Height
14.85 cm
35 °C
H57S HP Care Pack Advanced Unit Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £15.30
Brand: HP
