Boost your security, productivity, and connectivity with this Thunderbolt 4 dock. It protects your network and devices from the moment you log in, supports multi-OS compatibility, and can support up to four 4K displays. Ideal for ITDMs and hybrid workers, this dock also makes home or office device management easy.
Modern Device Manageability
With Intel vPro Active Management Technology, authorized administrators can remotely access notebooks using wired connections, even if turned off, to make updates. -
Electronic Asset Management for Your Docks
Empower your IT to manage and track your docks by product name, serial number, and MAC Address from anywhere with the time-saving, easy-to-use Electronic Tag (eTag) asset management tool. -
Thoughtful Product Packaging
HP is committed to reducing plastic in landfills by using recyclable, fiber-based, and sustainably sourced packaging that meets recycling requirements, so it can stay out of the landfill when customers are finished with it. -
We Test So You Can Rest
Rigorous testing helps assure dock compatibility across select HP notebooks and select Apple , Dell, and Lenovo notebooks with USB-C power ports. -
More Ports. More Flexibility
More ports means more capabilities. With a TB4 , HDMI, two USB-C , two DisplayPorts , four USB-A 3.2 ports and an RJ45 port, you can connect multiple devices like a keyboard and mouse. -
1-year Limited Warranty
Get added peace of mind with a 1-year limited warranty that includes technical support, diagnostic services, and hardware replacement.
- HP Thunderbolt Dock G4 - docking station - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE
- Product Type
- Docking station
- Video Interfaces
- 9.8 cm x 9.8 cm x 6.8 cm
- 760 g
- Black
- Localisation
- English / United Kingdom
- Networking
- Gigabit Ethernet, 2.5 Gigabit Ethernet
- Power
- Power adapter AC 100-240 V (50 - 60 Hz) 120 Watt Power Provided
- 1-year warranty
- Product Type
- Docking station
- 9.8 cm
- 9.8 cm
- 6.8 cm
- 760 g
- Enclosure Colour
- Black
- Localisation
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
- 4 x USB 3.2 Gen 1 , 1 x USB-C 3.2 Gen 2 , 1 x display / video / USB - Thunderbolt , 1 x network - 1000Base-T - RJ-45 , 1 x display / video - DisplayPort - 24 pin USB-C , 1 x display / video - HDMI , 2 x audio / video - DisplayPort - 20 pin DisplayPort
- Security lock slot (cable lock sold separately), charging via USB, LED indicator
- Security Slot Type
- Kensington security slot
- Power Device
- Power adapter
- Voltage Required
- AC 100-240 V (50 - 60 Hz)
- Power Provided
- 120 Watt
- Limited warranty - 1 year
- Shipping Width
- 27.5 cm
- Shipping Depth
- 14.3 cm
- Shipping Height
- 14.85 cm
- 0 °C
- 35 °C
