Reinvent docking and boost productivity with our most versatile Thunderbolt dock, the small, sophisticated HP Thunderbolt Dock G2. Designed for workspace flexibility and network manageability, it delivers USB-C device connectivity and optional integrated audio.
Command your workspace from a single Thunderbolt 3 (USB-C) connection
Connect the included cable to your notebook to access a wired network, data, video, and charging with a dock that supports both HP and non-HP Thunderbolt and USB-C notebooks. -
Reset your perception
Reclaim your work area with this space-saving centerpiece that helps create a clean desk. Its elegant, black, rounded design with smooth accents changes everything you thought you knew about docks. -
Manage your enterprise fleet like a boss
Help IT easily secure and remotely manage a wide range of HP notebooks and the dock with advanced network manageability features built into the dock, including WoL and MAC address pass-through in all power states and PXE Boot.
- HP Thunderbolt Dock G2 - docking station - VGA, DP, 2 x DP
- Product Type
- Docking station
- Video Interfaces
- VGA, DP, 2 x DP
- 9.8 cm x 9.8 cm x 6.9 cm
- 800 g
- Localisation
- English / United Kingdom
- Power
- Power adapter 120 Watt Power Provided
- 1-year warranty
- Product Type
- Docking station
- 9.8 cm
- 9.8 cm
- 6.9 cm
- 800 g
- Localisation
- 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB-C , 1 x headphone/microphone combo jack - mini-phone 3.5 mm , 1 x display / video / USB - Thunderbolt , 1 x network - Ethernet - RJ-45 , 1 x display / video - DisplayPort - 24 pin USB-C , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x audio / video - DisplayPort - 20 pin DisplayPort
- Cables Included
- 1 x USB-C cable - 70 cm
- Security lock slot (cable lock sold separately), charging via USB, LED indicator
- Security Slot Type
- Kensington security slot
- Power Device
- Power adapter
- Power Provided
- 120 Watt
- Limited warranty - 1 year
- 0 °C
- 35 °C
