HP ThinPro light 1GB DDR3 SODIMM 512MB Flash
Quicklinx: 7MDRWS00 Mfr#: XW887AT#ABU
  • Microsoft Windows 7 Home Premium 64-bit Edition
Too smart to be called zero, the HP t5335z Smart Client is a uniquely intelligent zero client that adapts to your environment. Deploy for Citrix XenDesktop with support for HDX, or choose VMware View or Microsoft Session Virtualization via rDesktop.
  • Zero configuration
    HP Smart Clients include an installation wizard for quick host server configuration. Intelligence is then automatically inherited from the data center, which drastically reduces solution implementation and deployment time.Simply connect the HP Smart Client to the network and a user monitor, keyboard and mouse - and you're on. The user is up and running quickly with no local user interface and just three steps from log-on to productivity.
  • Zero management
    At each boot up, the HP t5335z Smart Client automatically identifies the assigned environment from the server in seconds – even if the client virtualization software has been transitioned to a new environment.The HP Smart Client receives seamless updates as needed without individual IT support or interrupting the user session.Users have the flexibility to use the Profile Editor to make connection or preference changes in just a few clicks. Fall-back Intelligence on the client allows users to stay connected even if the server is offline.
  • Zero compromise
    HP Auto-sensing technology automatically connects to the network and searches for the right Citrix, VMware or Microsoft client virtualization infrastructure and downloads everything it needs to deliver a robust user experience.Deploy HP Smart Clients with the peace of mind that if your client virtualization software changes your HP Smart Clients will adapt to your environment. Simply repurpose your HP Smart Client for another protocol, saving time and money.Powerful ARM processor technology produces low heat emissions and delivers a rich, 1080p multimedia computing experience in Citrix XenDesktop environments.The solid-state design of the HP t5335z is near silent and fits in your environment - even attached to the back of a monitor with the HP QuickRelease - leaving no footprint for maximum workspace efficiency.HP Thin Clients are built to last with a computing platform designed for a complete lifecycle. And, these consistently reliable products are engineered and designed with quality in mind with a support community to back it up.
HPE Smart Client t5335z - SFF - ARMADA 510 1.2 GHz - 1 GB - flash 512 MB
Thin client - small form factor
1 x Marvell ARMADA 510 / 1.2 GHz
Cache Memory
512 KB
Cache Per Processor
512 KB
RAM
1 GB DDR3 SDRAM
Hard Drive
Flash 512 MB
Optical Storage
No optical drive
Audio Output
Stereo - integrated
GigE
16 cm x 12 cm x 3.2 cm
480 g
Environmental Standards
ENERGY STAR Qualified
Thin client
Recommended Use
Small business, corporate business
Product Form Factor
Small form factor
Built-in Devices
Speaker
Processor / Chipset
CPU
Marvell ARMADA 510
Clock Speed
1.2 GHz
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
512 KB
Cache Per Processor
512 KB
RAM
Installed Size
1 GB
DDR3 SDRAM
Hard Drive
Flash
512 MB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA, DVI
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
96 kHz
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Integrated
DHCP support
1 x DVI-I , 1 x VGA (with adapter) , 4 x USB 2.0 (2 front, 2 rear) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
FCC Class B certified, VCCI, GS, CB, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, WEEE
Power adapter
Power Provided
36 Watt
Operating System / Software
OS Certified
Microsoft Windows Server 2003 Terminal Server, Microsoft Windows Server 2000 Terminal Server, Microsoft Windows Server 2008, Citrix Presentation Server 4.5, Citrix Presentation Server 4.0
ENERGY STAR Certified
16 cm
12 cm
3.2 cm
480 g
10 °C
35 °C
10 - 90% (non-condensing)
