HP Thin Client t620 AMD GX217GA 1.65 GHz Dual Core 4GB 16GB Windows Embedded 8 Standard
PRICE DROP!
Last Few Remaining
Clearance
Price Drop
Quicklinx: B4QYWS00 Mfr#: F0U89ET#ABU
Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 Flexible Series Thin Client.
  • Integrated, complete peripheral support
    Choose from a range of ports to support your business now and in the future.
  • Reliable connectivity options
    Pick the technology that's best for you-choose from two optional enterprise-class, factory-installed Wi-Fi NICs with internal antennas or optional integrated HP 100 Mbps Mini PCIe SC Fiber NIC.
  • Drive up to four displays
    Support single, dual or quad digital display setups, or choose legacy VGA.
  • High-performance processors
    Choose the dual-or quad-core AMD GX processor and AMD HD professional graphics combination best suited to your business.
  • Software with HP extras
    Pick the HP enhanced OS environment that's ideal for your budget and performance requirements.
HP Flexible t620 - tower GX-217GA 1.65 GHz - 4 GB - SSD 16 GB - TAA Compliant
Thin client - tower
1 x AMD GX-217GA 1.65 GHz (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
Hard Drive
SSD 16 GB - SATA - mSATA
Optical Storage
No optical drive
Graphics Controller
AMD Radeon HD 8280E
Audio Output
Stereo - integrated
1GbE
OS Provided
Windows Embedded 8 Standard x64 Edition
4 cm x 22 cm x 24 cm
1.36 kg
Manufacturer Selling Program
HP Smart Buy
TAA Compliant
Environmental Standards
ENERGY STAR Qualified
Thin client
Recommended Use
Small business, corporate business
Product Form Factor
Tower
Processor / Chipset
CPU
AMD GX-217GA
Clock Speed
1.65 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
SSD - mSATA
1 x 16 GB
Interface Type
SATA
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 8280E
Video Interfaces
VGA, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Integrated
Wake on LAN (WoL), DHCP support, PXE support
Slots
1 (total) / 0 (free) x mSATA , 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 1 (free) x M.2 Card
6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE
HP Smart Buy
TAA Compliant
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
OS Certified
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012
Sustainability Information
ENERGY STAR Certified
4 cm
22 cm
24 cm
1.36 kg
10 °C
10 - 90% (non-condensing)
