HP Thin Client t5545 ThinPro 1Ghz 512F 512R Linux
Quicklinx: 5GZ8WS00 Mfr#: FU252ET#ABU
  • Microsoft Windows 2000 Advanced Server
The HP t5545 running HP ThinPro provides access to Windows, Citrix, mainframes, servers, Unix/Linux hosts, and web applications. The Firefox browser, terminal emulation, and support for common connection brokers make it ideal for business use.
HP t5545 - tower Eden 1 GHz - 512 MB - flash 512 MB
Thin client - tower
1 x VIA Eden 1 GHz
RAM
512 MB (installed) / 512 MB (max) - DDR2 SDRAM - non-ECC - PC2-4200
Hard Drive
Flash 512 MB
Graphics Controller
VIA Chrome9 HC3 - up to
Audio Output
Stereo - integrated
1GbE
OS Provided
HP ThinPro
Software Included
Citrix ICA, Microsoft Internet Explorer 6.0, Altiris Deployment Solution, Microsoft RDP 6.0
5.2 cm x 21.6 cm x 21 cm
1.5 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Thin client
Product Form Factor
Tower
Processor / Chipset
CPU
VIA Eden
Clock Speed
1 GHz
CPU Qty
1
Max CPU Qty
1
Chipset Type
VIA VX800
RAM
Installed Size
Effective Memory Speed
533 MHz
Rated Memory Speed
533 MHz
Memory Specification Compliance
PC2-4200
SO-DIMM 200-pin
Slots
1 (Total) / 0 (empty)
Unbuffered
Configuration Features
1 x 512 MB
Hard Drive
Flash
512 MB
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
VIA Chrome9 HC3
Max Allocated RAM Size
64 MB
Video Interfaces
VGA, DVI
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Integrated
Wake on LAN (WoL), DHCP support
Slots
1 (total) / 0 (free) x SO-DIMM 200-pin
6 x USB 2.0 (2 in front) , 1 x serial , 1 x parallel , 2 x PS/2 keyboard / mouse , 1 x VGA , 1 x LAN , 1 x headphones , 1 x microphone , 1 x DVI-D
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, UL 1950, EN55022 Class B, CB, UL 60950-1, IEC 60950-1, EN 60950-1
HP Smart Buy
Power adapter
Operating System / Software
OS Provided
HP ThinPro
OS Certified
Microsoft Windows 2000 Server, Microsoft Windows 2000 Advanced Server, Citrix Presentation Server, Microsoft Windows Server 2003, Microsoft Windows Server 2008
Software
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
5.2 cm
21.6 cm
21 cm
1.5 kg
10 °C
10 - 90%
Resources
The following resources are available for the HP Thin Client t5545 ThinPro 1Ghz 512F 512R Linux
