The HP t5545 running HP ThinPro provides access to Windows, Citrix, mainframes, servers, Unix/Linux hosts, and web applications. The Firefox browser, terminal emulation, and support for common connection brokers make it ideal for business use.
- HP t5545 - tower Eden 1 GHz - 512 MB - flash 512 MB
- Thin client - tower
- Localisation
- Processor
- 1 x VIA Eden 1 GHz
- RAM
- 512 MB (installed) / 512 MB (max) - DDR2 SDRAM - non-ECC - PC2-4200
- Hard Drive
- Flash 512 MB
- Graphics Controller
- VIA Chrome9 HC3 - up to
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- HP ThinPro
- Software Included
- Citrix ICA, Microsoft Internet Explorer 6.0, Altiris Deployment Solution, Microsoft RDP 6.0
- 5.2 cm x 21.6 cm x 21 cm
- 1.5 kg
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Thin client
- Product Form Factor
- Tower
- Localisation
Processor / Chipset
- CPU
- VIA Eden
- Clock Speed
- 1 GHz
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- VIA VX800
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 533 MHz
- Rated Memory Speed
- 533 MHz
- Memory Specification Compliance
- PC2-4200
- Form Factor
- SO-DIMM 200-pin
- Slots
- 1 (Total) / 0 (empty)
- Unbuffered
- Configuration Features
- 1 x 512 MB
Hard Drive
- Flash
- Capacity
- 512 MB
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- VIA Chrome9 HC3
- Max Allocated RAM Size
- 64 MB
- Video Interfaces
- VGA, DVI
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
Input Device
- Mouse, keyboard
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), DHCP support
- Slots
- 1 (total) / 0 (free) x SO-DIMM 200-pin
- 6 x USB 2.0 (2 in front) , 1 x serial , 1 x parallel , 2 x PS/2 keyboard / mouse , 1 x VGA , 1 x LAN , 1 x headphones , 1 x microphone , 1 x DVI-D
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, TUV GS, VCCI, UL 1950, EN55022 Class B, CB, UL 60950-1, IEC 60950-1, EN 60950-1
- HP Smart Buy
- Power adapter
- Voltage Required
Operating System / Software
- OS Provided
- HP ThinPro
- OS Certified
- Microsoft Windows 2000 Server, Microsoft Windows 2000 Advanced Server, Citrix Presentation Server, Microsoft Windows Server 2003, Microsoft Windows Server 2008
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 5.2 cm
- 21.6 cm
- 21 cm
- 1.5 kg
- 10 °C
- 40 °C
- 10 - 90%
