Easy setup. Simple management. Preinstalled with HP ThinPro operating system this all-inclusive access device is designed to provide a single console interface for dashboard access to all local resources making setup straightforward.
Fast setup, simple management
HP easy tools takes the guess work out of thin client setup by streamlining configuration and management applications into easy-to-follow screens that help you choose the right configurations for your environment. HP easy tools utilities include HP EZ Update which delivers automatic image updates, low bandwidth add-ons and configuration changes to like devices and HP Device Manager which simplifies visibility and control in more complex network environments. -
PC productivity, flexibility
Connect to the latest in display technology with native dual-digital monitor support or connect to an analog monitor using the included DVI-I to VGA adapter. Standard configurations include 6 USB 2.0 ports, legacy ports, and an HP-exclusive power cord retention slot. You'll experience traditional PC performance and multimedia playback while using less electricity. Energy star qualified configurations help reduce power consumption.
- HP t5565 - tower - Nano U3500 1 GHz - 2 GB - flash 1 GB
- Thin client - tower
- Localisation
- Processor
- 1 x VIA Nano U3500 / 1 GHz
- Cache Memory
- 1 MB
- Cache Per Processor
- 1 MB
- RAM
- 2 GB DDR3 SDRAM
- Hard Drive
- Flash 1 GB
- Optical Storage
- No optical drive
- Graphics Controller
- VIA ChromotionHD 2.0 Shared Video Memory (UMA)
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- HP ThinPro
- Software Included
- HP Easy Tools, HP Client Automation, HP Device Manager
- 5.8 cm x 21.6 cm x 21 cm
- 1.36 kg
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Thin client
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Tower
- Built-in Devices
- Speaker
- Localisation
Processor / Chipset
- CPU
- VIA Nano U3500
- Clock Speed
- 1 GHz
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- VIA VX900
Cache Memory
- Installed Size
- 1 MB
- 1 MB
RAM
- Installed Size
- 2 GB
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
Hard Drive
- Flash
- Capacity
- 1 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DVI
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
Input Device
- Mouse, keyboard
- Integrated
- Data Link Protocol
- Remote Management Protocol
- Telnet, SSH
- Wake on LAN (WoL), DHCP support
- Slots
- SO-DIMM 204-pin
- 6 x USB 2.0 , 1 x serial , 1 x parallel , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x DVI-D , 1 x DVI-I
- Cables Included
- DVI-VGA adapter
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, VCCI, GS, CB, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03
- HP Smart Buy
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- HP ThinPro
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 5.8 cm
- 21.6 cm
- 21 cm
- 1.36 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
HP Thin Client - T5565 - 2 GB RAM - 1 GHz
