Built to match the way you live and designed to use with the HP Smart app, Tango helps you stay a step ahead by connecting and printing from any device, anywhere.
Dynamic security enabled printer. Intended to be used with cartridges using only HP original electronic circuitry. Cartridges with modified or non-HP electronic circuitry may not work, and those that work today may not work in the future.
Smart and simple
Get connected and start printing fast with seamless Wi-Fi setup from your smartphone.Easily print from a variety of smartphones, tablets, and laptops.Have confidence in your connection with steady performance from dual band Wi-Fi . -
More connected than ever
Easily print everyday documents from your smartphone.Get high-quality scanning, and share to email or the cloud – from virtually anywhere.Make a copy from your smartphone with HP Smart app and send it to your printer from virtually anywhere.Get notifications when printing, scanning, or copying from your smartphone. -
Save up to 70% on ink with HP Instant Ink
Save on ink and get it automatically delivered to your door. Ink cartridges and delivery costs included in your monthly plan price.Get rich black text and vibrant graphics for all your everyday documents.HP 303 ink cartridges deliver authentic colours so all your prints will shine.No annual fee – change or cancel plans online anytime without penalty. -
Your photos print free
Print photos from your smartphone for free, with Tango and HP Instant Ink.
- HP Tango - printer - colour - ink-jet - HP Instant Ink eligible
- Printer Type
- Photo printer - ink-jet - colour
- 3.08 kg
- Localisation
- Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 20 ppm - black draft - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 11 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 19 ppm - colour draft - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 8 ppm - color (ISO) , Up to 0.62 ppm - colour photo - 100 x 150 mm
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Interface
- Wi-Fi(n), Bluetooth LE
- Processor
- 360 MHz
- RAM Installed (Max)
- 256 MB (256 MB) - DDR3 SDRAM
- Language Simulation
- HP PCL 3 GUI
- Media Type
- Labels, plain paper, photo paper, cards, recycled paper, thick paper, light-weight paper, glossy paper, matte paper
- Total Media Capacity
- 50 sheets
- Media Handling
- 50-sheet input tray
- Monthly Duty Cycle (max)
- 500 pages
- Recommended Monthly Volume
- 100 - 300 pages
- Networking
- Print server
- Printer Features
- Print from mobile device, Auto Power Off
- System Requirements
- Microsoft Windows 7 / 8 / 8.1 / 10, Apple OS X 10.11 El Capitan, Apple macOS Sierra 10.12, Apple macOS High Sierra 10.13
- Enclosure Colour
- Wisp grey
- 1-year warranty
- 37.7 cm x 20.6 cm x 9.1 cm
- Printer Type
- Enclosure Colour
- Wisp grey
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 704 nozzles (black), 684 nozzles (colour)
- Ink Cartridge Configuration
- 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- 4800 x 1200 dpi
- HP PCL 3 GUI
- Colour Management Features
- ColorLok Technology
- Printer Features
- Media Handling
- Processor
- 360 MHz
RAM
- 256 MB / 256 MB (max)
- Technology / Form Factor
- DDR3 SDRAM
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 101.6 x 152.4 mm, 127 x 177.8 mm, 203.2 x 254 mm
- Borderless Photo Sizes
- 130 x 180 mm
- Envelope Sizes
- International DL (110 x 220 mm)
- Media Weight
- 60 g/m² - 300 g/m²
- Media Weight (lbs)
- 16 lbs - 110 lbs
- 50 sheets
- Media Feeders
- Input tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m² - (16 lbs (min) - 110 lbs (max)) , Output tray: 1 - 20 sheets
- Max Media Capacity
- 50 sheets
- Output Trays Capacity
- 20 sheets
Duty Cycle
- 500 pages
- 100 - 300 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP, IPP, SLP
- Consumables Included
- 1 x ink cartridge (black) - up to 125 pages - HP 303 , 1 x ink cartridge (yellow/cyan/magenta) - up to 110 pages - HP 303
- FCC Class A certified, BSMI, GS, CCC, FCC CFR47 Part 15, UL 60950-1 Second Edition, RCM, IEC 62368-1, UL 62368-1 Second Edition, ICES-003 issue 6, Directive 2014/53/EU, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- Software Included
- Drivers & Utilities, HP Photo Creations, HP Update
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year , Technical support - 1 year , Technical support - web support - response time: 24 hours / Monday-Sunday
- 5 °C
- 40 °C
- 5 - 80% (non-condensing)
- 37.7 cm
- 20.6 cm
- 9.1 cm
- 3.08 kg
- Width (Shipping)
- 50.2 cm
- Depth (Shipping)
- 26.9 cm
- Height (Shipping)
- 15.1 cm
- Weight (Shipping)
- 4.24 kg
Ink (2)
HP 303XL High Yield Black Original Ink Cartridge | In Stock | £31.04 |
HP 303XL High Yield Tri-color Original Ink Cartridge | In Stock | £35.10 |
Other bundles (3)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment | In Stock | £21.99 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment | In Stock | £24.26 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 2 Years Shipment | In Stock | £16.47 |
