HP T730 AMD RX427BB 8GB 32GB Windows Embedded Std 7 Pro
Quicklinx: C153WS00 Mfr#: P3S25AA#ABU
  • AMD Radeon R7
in stock
£442.83 ex VAT
£531.39 inc VAT
Goodbye add-ons, extras, and optional features. The HP t730 Thin Client, HP's most powerful desktop thin client, is ready to deploy in demanding environments right out of the box with an AMD quad-core processor, maximum interfaces, OS and ISV choices, and native support for 4 UHD/4K displays.
  • Feels like face-to-face
    Experience broadened support for unified communications (UC) solutions such as Skype for Business.
  • Keep it simple
    Make it easy to deploy, manage, and maintain your install base with HP Device Manager.
  • True 3D delivery you have to see to believe
    Brace yourself for breakthrough loss-less video and graphics presentation from the cloud with HP True Graphics software.
  • Super-charged data delivery
    Improve wired and Wi-Fi network performance and the end user experience with HP Velocity software.
  • Quick. Clean. Streamlined
    Simplify the HP Thin Client Windows Embedded user experience with HP Easy Shell's customized interface and protection for targeted cloud control.
  • Any network, anytime
    Connect to any type of network with the standard RJ-45 interface or an optional Wi-Fi or Fiber Optic network adapter.
HP t730 - tower RX427BB 2.7 GHz - 8 GB - flash 32 GB - UK - TAA Compliant
Thin client - tower
1 x AMD RX427BB / 2.7 GHz (up to 3.6 GHz, (Quad-Core)
Cache Memory
4 MB L2 Cache
Cache Per Processor
4 MB
RAM
8 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
Hard Drive
Flash 32 GB - M.2
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R7
1GbE
Keyboard
OS Provided
Microsoft Windows Embedded Standard 7P 64-bit
6.7 cm x 22.1 cm x 24 cm
1.8 kg
TAA Compliant
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
AMD RX427BB
Clock Speed
2.7 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 0 (empty)
Dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
Flash - M.2
1 x 32 GB
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R7
Video Interfaces
DisplayPort
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
USB
Wake on LAN (WoL), PXE support
Slots
1 (total) / 0 (free) x M.2 Card , 2 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x8 mode)
6 x USB 2.0 (2 front, 4 rear) , 3 x USB 3.0 (2 front, 1 internal) , 6 x DisplayPort , 2 x PS/2 keyboard / mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 2 x headphones/microphone (2 in front) , 1 x audio line-out , 1 x audio line-in
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, EN55022 Class B, low halogen
TAA Compliant
Power adapter
Power Provided
85 Watt
Operating System / Software
OS Provided
Microsoft Windows Embedded Standard 7P 64-bit English
6.7 cm
22.1 cm
24 cm
1.8 kg
10 °C
10 - 90% (non-condensing)
