Goodbye add-ons, extras, and optional features. The HP t730 Thin Client, HP's most powerful desktop thin client, is ready to deploy in demanding environments right out of the box with an AMD quad-core processor, maximum interfaces, OS and ISV choices, and native support for 4 UHD/4K displays.
Feels like face-to-face
Experience broadened support for unified communications (UC) solutions such as Skype for Business. -
Keep it simple
Make it easy to deploy, manage, and maintain your install base with HP Device Manager. -
True 3D delivery you have to see to believe
Brace yourself for breakthrough loss-less video and graphics presentation from the cloud with HP True Graphics software. -
Super-charged data delivery
Improve wired and Wi-Fi network performance and the end user experience with HP Velocity software. -
Quick. Clean. Streamlined
Simplify the HP Thin Client Windows Embedded user experience with HP Easy Shell's customized interface and protection for targeted cloud control. -
Any network, anytime
Connect to any type of network with the standard RJ-45 interface or an optional Wi-Fi or Fiber Optic network adapter.
- HP t730 - tower RX427BB 2.7 GHz - 8 GB - flash 32 GB - TAA Compliant
- Thin client - tower
- Localisation
- Processor
- 1 x AMD RX427BB / 2.7 GHz (up to 3.6 GHz, (Quad-Core)
- Cache Memory
- 4 MB L2 Cache
- Cache Per Processor
- 4 MB
- RAM
- 8 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
- Hard Drive
- Flash 32 GB - M.2
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon HD 9000
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 IoT Enterprise
- 6.7 cm x 22.1 cm x 24 cm
- 1.8 kg
- TAA Compliant
- Thin client
- Product Form Factor
- Tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD RX427BB
- Clock Speed
- 2.7 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- L2 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 0 (empty)
- Dual channel memory architecture
- Configuration Features
- 2 x 4 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 32 GB
- Multi-level cell (MLC)
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Slots
- 1 (total) / 0 (free) x M.2 Card , 2 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x8 mode)
- 6 x USB 2.0 (2 front, 4 rear) , 3 x USB 3.0 (2 front, 1 internal) , 4 x DisplayPort , 2 x PS/2 keyboard / mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 2 x headphones/microphone (2 in front) , 1 x audio line-out , 1 x audio line-in
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, EN55022 Class B, low halogen
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 85 Watt
Operating System / Software
- OS Provided
- Windows 10 IoT Enterprise English
- 6.7 cm
- 22.1 cm
- 24 cm
- 1.8 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
Warranties (1)
Other bundles (3)
HPE DisplayPort DVI-D Adapter | In Stock | £19.74 |
HPE DisplayPort to VGA Adapter | In Stock | £13.12 |
HPE USB to Serial Port Adapter | In Stock | £13.94 |
