HP T730 AMD Radeon RX 427BB 8GB Thin Client
Quicklinx: DZSZWS00 Mfr#: 3JJ11EA#ABU
Processor Type: R-series
Operating System: Microsoft Windows Embedded Standard 7P 64-bit / Windows 10 IOT Enterprise for Thin Clients 64-bit Edition downgrade
Installed Memory: 4GB
Hard Drive Capacity: 32GB
Storage Type: Flash
£659.89 ex VAT
£791.86 inc VAT
Goodbye add-ons, extras, and optional features. The HP t730 Thin Client, HP's most powerful desktop thin client, is ready to deploy in demanding environments right out of the box with an AMD quad-core processor, maximum interfaces, OS and ISV choices, and native support for 4 UHD/4K displays.
  • Premium performer
    Harness the power of AMD's latest generation quad-core APU with Turbo Core technology that can throttle CPU action and kick it up to 3.6 GHz to run full VDI and local applications and render video to four displays.
  • Expand your view with quad displays
    Create an efficient multi-monitor workspace with DisplayPort connections for up to four UHD/4K displays, or six displays with the discrete graphics card. Now you can enjoy a high pixel count, serious sharpness, and eye-popping details every day.
  • Integrated software sweetens the deal
    Streamline deployments, enhance the user experience, and enable smooth device management with HP's exclusive thin client software: HP Device Manager, HP Velocity, and HP Easy Shell.
  • Plan ahead with expansive I/O connections
    Support your business now and in the future with serial, parallel, PS/2, and USB ports plus a PCI Express x4 low profile expansion slot.
HP t730 - tower - R-series RX427BB 2.7 GHz - 4 GB - 32 GB
Thin client - tower
1 x AMD R-series RX427BB / 2.7 GHz (3.6 GHz) (Quad-Core)
Cache Memory
4 MB L2 Cache
Cache Per Processor
4 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3L-12800
Hard Drive
1 x flash 32 GB - M.2
Optical Storage
No optical drive
Graphics Controller
AMD Radeon HD 9000
GigE
OS Provided
Microsoft Windows Embedded Standard 7P 64-bit / Windows 10 IOT Enterprise for Thin Clients 64-bit Edition downgrade + Windows 10 IoT Enterprise for Thin Clients 64-bit Edition License
6.7 cm x 22.1 cm x 24 cm
1.8 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3L-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
Flash - M.2
1 x 32 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon HD 9000
Video Interfaces
DisplayPort
Wake on LAN (WoL), PXE support
Slots
1 (total) / 0 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe 3.0 x16 (x8 mode)
6 x USB 2.0 (2 front, 4 rear) , 3 x USB 3.0 (2 front, 1 internal) , 4 x DisplayPort , 2 x PS/2 keyboard / mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 2 x headphones/microphone (2 in front) , 1 x audio line-in , 1 x audio line-out
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, low halogen
Power adapter
Nominal Voltage
Power Provided
85 Watt
Operating System / Software
OS Provided
Microsoft Windows Embedded Standard 7P 64-bit / Windows 10 IOT Enterprise for Thin Clients 64-bit Edition downgrade + Windows 10 IoT Enterprise for Thin Clients 64-bit Edition License - English
ENERGY STAR Certified
6.7 cm
22.1 cm
24 cm
1.8 kg
10 °C
10 - 90% (non-condensing)
HP T730 AMD Radeon RX 427BB 8GB Thin Client Bundle deal on HP T730 AMD Radeon RX 427BB 8GB Thin Client
£846.35
saving £8.33
£751.43
Storage Type: Flash
Processor Model: RX427BB
Type: Thin client
Case Style: Tower
Optical Storage: None
Brand: HP
Price Range Ex VAT: 500 - 750
