Tackle your hybrid local and virtual computing workloads with the HP t640 Thin Client. Help keep your data and device safe across your workflows with built-in security features. Choose the right fit for your specific users and environment with a range of subsystem options.
Maximize what you can accomplish
Empower your workforce with performance that conquers every task-an AMD Ryzen R1505G processor, high-speed, responsive system memory, and native support for up to three UHD/4K displays. -
Refined security
Encrypt data as it flows between the system memory and processor, protect firmware, and lock down access with an inherently secure thin client that has AMD Memory Guard, an embedded OS, and a NIST SP800-193 component. -
Modern flexibility
Select from up to 35 different subsystem options, including wired or wireless networking and support for legacy peripherals. Conveniently position the thin client in up to six different orientations with an integrated VESA mount. -
Value-added software
Remotely setup and deploy your devices and get local-quality multimedia with exclusive software that makes our thin clients capable, responsive, and reliable.
- HP t640 - SFF - Ryzen Embedded R1505G 2.4 GHz - 4 GB - flash 16 GB - UK
- Thin client - small form factor
- Localisation
- Processor
- 1 x AMD Ryzen Embedded R1505G / 2.4 GHz (3.3 GHz) (Dual-Core)
- Cache Memory
- 4 MB L3 Cache
- Cache Per Processor
- 4 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Hard Drive
- Flash 16 GB - M.2
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon Vega 3
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- HP ThinPro
- 3.5 cm x 19.6 cm x 19.6 cm
- 994.5 g
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD Ryzen Embedded R1505G
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- L3 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 16 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon Vega 3
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 3
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111EPH-CG
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Slots
- 1 (total) / 0 (free) x M.2 Card
- 3 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone , 2 x USB 2.0 , 3 x USB 3.1 Gen 1 , USB 3.1 Gen 2 , 1 x USB-C 3.1 Gen 2 , 1 x audio line-out/line-in
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, UL, BSMI, GS, CB, CCC, EMC, RoHS, ICES Class B, WEEE, EN 60601-1-2, KCC Class B, ERP, CECP, VCCI Class B, CISPR Class B, SEPA, HP GSE, EN, CNS
- Power adapter
- Voltage Required
- Power Provided
- 45 Watt
Operating System / Software
- OS Provided
- HP ThinPro English
- ENERGY STAR Certified
- 3.5 cm
- 19.6 cm
- 19.6 cm
- 994.5 g
- Shipping Weight
- 2.878 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
Warranties (4)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only | In Stock | £25.29 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years | In Stock | £49.36 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment | In Stock | £37.31 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year | In Stock | £18.06 |
Monitors (2)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £150.00 |
Other bundles (8)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HPE DisplayPort DVI-D Adapter | In Stock | £13.23 |
HPE DisplayPort to VGA Adapter | In Stock | £16.40 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £135.29 |
APC BACK-UPS BE650G2-UK 650VA 230V | In Stock | £100.76 |
APC BACK-UPS BE850G2-UK 850VA 230V USB | In Stock | £112.43 |
APC BACK UPS PRO BR650MI 650VA 6 Outlets | In Stock | £143.52 |
APC BACK UPS PRO BR900MI 900VA 6 Outlets | In Stock | £205.60 |
