HP t630 - Thin client - tower - 1 x GX-420GI 2 GHz
Quicklinx: CH56WS00 Mfr#: X4X16AT#ABU
Optimize your cloud-based deployments with the powerful, highly configurable, and long lifecycle HP t630 Thin Client. Support your business now and in the future with quad-core processing, dual UHD/4K display compatibility, and options for device and network connectivity and local storage.
Designed to go above and beyond
Speed performance with an expertly engineered thin client driven by an embedded x86 quad-core system-on-a-chip. The integrated AMD Radeon graphics engine supports up to two UHD/4K displays for a fantastic media experience.
Bridge the gap with expansive connectivity
Configure a precise deployment with legacy ports for your reliable peripherals, dual-channel DDR4 system memory, wired or optional wireless or fiber connectivity, and optional local dual flash memory up to 128 GB for separate, discrete storage.
Software with all the extras, minus the extra cost
Tailor your OS environment, remotely set up and deploy, boost Wi-Fi and network performance, and get local-quality multimedia on the cloud with exclusive HP value-added software: HP Device Manager, HP Velocity, HP True Graphics, and HP Easy Shell.
  • Legacy and future peripheral support
    Keep the peripherals you know and trust and plan ahead with connections that include PS/2 and serial ports, an optional VGA output or second serial port, and convenient front and rear USB 3.0 and USB 2.0 ports.
  • Next-level security
    Protect data with VDI and cloud hosting, certified TPM, a BIOS designed to National Institute of Standards and Technology (NIST) specs, and Windows with Write Filter protection.
  • Pro-class collaboration
    Stay in contact with colleagues with support for unified communications (UC) solutions.
  • If it's a network, you can connect to it
    Go wired with standard RJ-45, wireless with an optional Wi-Fi/Bluetooth or external Wi-Fi antenna system, or connect to fiber with an optional Fiber Optic network adapter.
  • Ready for browser-based productivity
    Work with your choice of subscription-based SaaS solutions like Office 365.
  • Add your favorite OS
    Pick a familiar and reliable Windows or Linux OS and pair with your own ISV.
HP t630 - tower GX-420GI 2 GHz - 4 GB - flash 8 GB
Thin client - tower
1 x AMD GX-420GI 2 GHz (up to 2.2 GHz, (Quad-Core)
Processor Main Features
AMD Turbo CORE Technology
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Hard Drive
Flash 8 GB - M.2
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R6E
1GbE
OS Provided
HP Smart Zero Core 32-bit
Software Included
Citrix ICA, Microsoft RDP, HP Easy Tools, HP Device Manager, LogOn Manager, Citrix Receiver, HP TeemTalk Terminal Emulator, VMware Horizon View, Citrix HDX, HP Velocity, HP Smart Zero Client, FreeRDP, Microsoft RemoteFX, Mozilla Firefox 36
12 cm x 22 cm x 25.1 cm
1.52 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Processor / Chipset
CPU
AMD GX-420GI
Clock Speed
2 GHz
Max Turbo Speed
2.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
Flash - M.2
1 x 8 GB
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R6E
Video Interfaces
DisplayPort
Max Monitors Supported
2
Input Device
Mouse
Mouse
USB
Wake on LAN (WoL), PXE support
Slots
2 (total) / 1 (free) x SO-DIMM 260-pin , 1 M.2 Card - 2280 , 1 M.2 Card - 2242
2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 4 x USB 2.0 (4 front, 2 rear) , 2 x USB 3.0 (2 in front) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x audio line-in/headphones
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, EN55022 Class B
HP Smart Buy
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
HP Smart Zero Core 32-bit English
Software
Sustainability Information
ENERGY STAR Certified
12 cm
22 cm
25.1 cm
1.52 kg
10 °C
10 - 90% (non-condensing)
Warranties (4)
CH56 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only In Stock £24.71
CH56 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years In Stock £48.26
CH56 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment In Stock £36.49
CH56 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year In Stock £18.70
Other bundles (3)
CH56 HPE DisplayPort DVI-D Adapter In Stock £19.74
CH56 HPE DisplayPort to VGA Adapter In Stock £13.12
CH56 HPE USB to Serial Port Adapter In Stock £13.94
