HP t620 PLUS Flexible Thin Client AMD GX-420CA 4GB 32GB Windows Embedded Standard 7E 32-bit
Quicklinx: BCXPWS00 Mfr#: J9A38EA#ABU
Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 PLUS Flexible Series Thin Client.
  • Get flexibility where you need it
    Customize your thin client with everything you need and nothing you don't. Choose the configuration options and expansion capabilities that best fit your business and help ensure an ideal end user experience.
  • Tailor your hardware and software performance to your exact requirements
    Configure your deployment to provide a powerful seamless desktop experience for your end users without exceeding your budget.
  • Customize security the way you want
    Help protect your thin client environment with integrated and optional hardware and software security solutions, including: HP BIOS implemented to NIST guidelines, a TPM chipset, Fiber NIC communications, and lockable covers and ports.
  • Designed to give you peace of mind
    Reduce desktop service calls and product refreshes with a completely redesigned chassis that includes advanced passive cooling for fan-less support of quad-core processors.
HP Flexible t620 PLUS - tower GX-420CA 2 GHz - 4 GB - SSD 32 GB - UK - TAA Compliant
Thin client - tower
1 x AMD GX-420CA 2 GHz (Quad-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
Hard Drive
SSD 32 GB - SATA - mSATA
Optical Storage
No optical drive
Graphics Controller
AMD Radeon HD 8400E
Audio Output
Stereo - integrated
1GbE
Keyboard
OS Provided
Microsoft Windows Embedded Standard 7E 32-bit
6.5 cm x 22 cm x 24 cm
2.04 kg
TAA Compliant
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Recommended Use
Small business, corporate business
Product Form Factor
Tower
Built-in Devices
Speaker
Processor / Chipset
CPU
AMD GX-420CA
Clock Speed
2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total)
Low-voltage
Hard Drive
SSD - mSATA
1 x 32 GB
Interface Type
SATA
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 8400E
Video Interfaces
VGA, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Localization & Layout
Integrated
Wake on LAN (WoL), DHCP support, PXE support
Slots
1 (total) / 0 (free) x mSATA , 2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 1 (free) x PCIe x16 (x4 mode) , 1 (total) / 1 (free) x M.2 Card
6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x parallel , 1 x serial , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE
TAA Compliant
Power adapter
Power Provided
85 Watt
Operating System / Software
OS Provided
Microsoft Windows Embedded Standard 7E 32-bit English
OS Certified
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012
Sustainability Information
ENERGY STAR Certified
6.5 cm
22 cm
24 cm
2.04 kg
10 °C
10 - 90% (non-condensing)
