Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 Flexible Series Thin Client.
Integrated, complete peripheral support
Choose from a range of ports to support your business now and in the future. -
Reliable connectivity options
Pick the technology that's best for you-choose from two optional enterprise-class, factory-installed Wi-Fi NICs with internal antennas or optional integrated HP 100 Mbps Mini PCIe SC Fiber NIC. -
Drive up to four displays
Support single, dual or quad digital display setups, or choose legacy VGA. -
High-performance processors
Choose the dual-or quad-core AMD GX processor and AMD HD professional graphics combination best suited to your business. -
Software with HP extras
Pick the HP enhanced OS environment that's ideal for your budget and performance requirements.
- HP Flexible t620 - tower - GX-415GA 1.5 GHz - 4 GB - SSD 16 GB - TAA Compliant
- Thin client - tower
- Localisation
- Processor
- 1 x AMD GX-415GA 1.5 GHz (Quad-Core)
- Cache Memory
- 2 MB L2 Cache
- Cache Per Processor
- 2 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
- Hard Drive
- SSD 16 GB - SATA - mSATA
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon HD 8330E
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows Embedded Standard 7P 64-bit
- 4 cm x 22 cm x 24 cm
- 1.36 kg
- Manufacturer Selling Program
- HP Top Value
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - parts and labour - 3 years
- Thin client
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Tower
- Localisation
Processor / Chipset
- CPU
- AMD GX-415GA
- Clock Speed
- 1.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- L2 Cache - 2 MB
- 2 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- SSD - mSATA
- Capacity
- 1 x 16 GB
- Interface Type
- SATA
- Multi-level cell (MLC)
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Standard Keyboard
- Interface
- USB
Mouse
- Technology
- Optical
- Interface
- USB
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), DHCP support, PXE support
- Slots
- 1 (total) / 0 (free) x mSATA , 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 1 (free) x M.2 Card
- 6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x VGA
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE
- HP Top Value
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- OS Certified
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 4 cm
- 22 cm
- 24 cm
- 1.36 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
