HP t620 Flexible Thin Client AMD GX-415GA 4GB 16GB Windows Embedded Standard 7P 64-bit
Quicklinx: BCXZWS00 Mfr#: G6F29AA#ABU
Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 Flexible Series Thin Client.
  • Integrated, complete peripheral support
    Choose from a range of ports to support your business now and in the future.
  • Reliable connectivity options
    Pick the technology that's best for you-choose from two optional enterprise-class, factory-installed Wi-Fi NICs with internal antennas or optional integrated HP 100 Mbps Mini PCIe SC Fiber NIC.
  • Drive up to four displays
    Support single, dual or quad digital display setups, or choose legacy VGA.
  • High-performance processors
    Choose the dual-or quad-core AMD GX processor and AMD HD professional graphics combination best suited to your business.
  • Software with HP extras
    Pick the HP enhanced OS environment that's ideal for your budget and performance requirements.
HP Flexible t620 - tower - GX-415GA 1.5 GHz - 4 GB - SSD 16 GB - TAA Compliant
Thin client - tower
1 x AMD GX-415GA 1.5 GHz (Quad-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
Hard Drive
SSD 16 GB - SATA - mSATA
Optical Storage
No optical drive
Graphics Controller
AMD Radeon HD 8330E
Audio Output
Stereo - integrated
1GbE
OS Provided
Microsoft Windows Embedded Standard 7P 64-bit
4 cm x 22 cm x 24 cm
1.36 kg
TAA Compliant
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 3 years
Thin client
Recommended Use
Small business, corporate business
Product Form Factor
Tower
Processor / Chipset
CPU
AMD GX-415GA
Clock Speed
1.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Low-voltage
Configuration Features
1 x 4 GB
Hard Drive
SSD - mSATA
1 x 16 GB
Interface Type
SATA
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 8330E
Video Interfaces
DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Mouse
Optical
USB
Integrated
Wake on LAN (WoL), DHCP support, PXE support
Slots
1 (total) / 0 (free) x mSATA , 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 1 (free) x M.2 Card
6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x serial
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE
TAA Compliant
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
OS Certified
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
4 cm
22 cm
24 cm
1.36 kg
10 °C
10 - 90% (non-condensing)
Warranties (1)
BCXZ HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year In Stock £18.01
Other bundles (2)
BCXZ HPE DisplayPort DVI-D Adapter In Stock £19.77
BCXZ HPE USB to Serial Port Adapter In Stock £13.95
