HP t610 Flexible Thin Client delivers added security, broad expansion options and a PC-like multimedia experience for virtualized desktops. A flexible solution with a powerful boost in performance.
Advanced technology, high-end deployment
The HP t610 Flexible Series Thin Clients deliver a true, PC-like experience for virtualized desktop environments. AMD's APU technology, combining dual core processor with AMD HD 6320 graphics. -
Eco-highlights
HP t610 Flexible Series Thin Client is built with the environment in mind.
- HP Flexible t610 - tower - G-T56N 1.65 GHz - 4 GB - flash 1 GB
- Thin client - tower
- Localisation
- Processor
- 1 x AMD G-T56N 1.65 GHz (Dual-Core)
- Cache Memory
- 1 MB L2 Cache
- Cache Per Processor
- 1 MB
- RAM
- 4 GB (installed) / 4 GB (max) - DDR3 SDRAM - PC3-12800
- Hard Drive
- Flash 1 GB
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon HD 6320
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- HP Smart Zero Technology
- Software Included
- Rdesktop 1.6, Microsoft RDP 6.0, HP ThinState Tools, HP Connection Manager, Citrix ICA 12.0, HP Easy Tools, HP Device Manager, HP TeemTalk Terminal Emulator 7, VMware View Manager 4.6
- 4 cm x 22 cm x 24 cm
- 1.49 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Thin client
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Tower
- Localisation
Processor / Chipset
- CPU
- AMD G-T56N
- Clock Speed
- 1.65 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
- Chipset Type
- AMD A55E
Cache Memory
- Installed Size
- L2 Cache - 1 MB
- 1 MB
RAM
- Installed Size
- 4 GB / 4 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total)
Hard Drive
- Flash
- Capacity
- 1 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DVI, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
Input Device
- Mouse, keyboard
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), DHCP support, PXE support
- IEEE 802.1x
- Slots
- 2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Half Mini Card
- 4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 , 1 x DVI-I , 1 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in/microphone (1 in front) , 1 x audio line-out/headphones (1 in front)
- Cables Included
- DVI-VGA adapter
- Theft/Intrusion Protection
- FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, ZH1 618, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- OS Certified
- Microsoft Windows Server 2003, Microsoft Windows Server 2003 Terminal Server, Microsoft Windows Server 2008 Terminal Server, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenDesktop 4, Citrix XenApp 5, Citrix XenApp 6
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 4 cm
- 22 cm
- 24 cm
- 1.49 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
