HP T610 Plus WES7P 16SF/4GR ES TC
Quicklinx: 8Y73WS00 Mfr#: B8D15AA#ABU
Processor Type: G-T56N
Operating System: Microsoft Windows Embedded Standard 7P
Installed Memory: 4GB
Hard Drive Capacity: 16GB
Storage Type: Flash
£497.20 ex VAT
£596.64 inc VAT
HP t610 Flexible Thin Client delivers added security, broad expansion options and a PC-like multimedia experience for virtualized desktops. A flexible solution with a powerful boost in performance.
  • Advanced technology, high-end deployment
    AMD's APU technology, combining dual core processors with AMD HD 6320 graphics. Features DirectX 11 graphics support, DDR3-1600 RAM with up to 4 GB of capacity and AMD A55E Chipset with DVI-I and DisplayPort outputs.Reduce poor network connectivity in densely populated work environments with HP Velocity, a new HP feature. As network conditions change, HP Velocity reacts to maintain the highest quality performance.
  • A flexible PC-alternative
    The HP t610 PLUS Flexible Thin Client features 6 USB ports: 2 USB 3.0 ports, 4 USB 2.0 ports, and PS/2 legacy ports, as well as 2 serial and 1 parallel ports. Use the standard Gigabit Ethernet or built-in WiFi option with dual, internal antennas (WiFi depending on model).
  • Software flexibility
    Preloaded with HP's TPM Chip built-in security feature, NIST-certified BIOS support, optional dual WiFi internal antennas, cable lock slot and power cord retention slot to prevent accidental power-off.
  • Intuitive network management
    Featuring HP Velocity and HP Thermal Protection. Eliminate network noise while maintaining high-quality performance, and guard against data loss induced by overheating.
  • Eco-highlights
    The HP t610 PLUS Flexible Thin Client is built with the environment in mind, including BFR/PVC-Free and post-Consumer Recycled Plastics > 20% (excluding PCB), ENERGY STAR qualified, EPEAT Gold registered.
  • HP service and dependability
    Easy setup, easy manageability and easy maintenance. With HP t610 PLUS Flexible Thin Client, you can select from a range of HP Care Pack Services for support beyond standard.
HP Flexible t610 PLUS - tower - G-T56N 1.65 GHz - 4 GB - 16 GB
Thin client - tower
1 x AMD G-T56N 1.65 GHz (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 4 GB (max) - DDR3 SDRAM
Hard Drive
Flash 16 GB
Optical Storage
No optical drive
Graphics Controller
AMD Radeon HD 6320
Audio Output
Stereo - integrated
GigE
OS Provided
6.5 cm x 22 cm x 24 cm
1.98 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - 3 years
Thin client
Recommended Use
Small business, corporate business
Product Form Factor
Tower
Built-in Devices
Speaker
Processor / Chipset
CPU
AMD G-T56N 1.65 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Chipset Type
AMD A55E
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 4 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
SO-DIMM 204-pin
Slots
2 (Total)
Hard Drive
Flash
16 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 6320
Video Interfaces
VGA, DVI, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
44 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
PS/2
Mouse
Optical
PS/2
Wake on LAN (WoL), DHCP support, PXE support
Slots
2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe x16 - low-profile (x4 mode)
4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 , 1 x DVI-I , 1 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in/microphone (1 in front) , 1 x audio line-out/headphones (1 in front)
DVI-VGA adapter
Theft/Intrusion Protection
FCC Class B certified, TUV GS, VCCI, EN55022, UL 1950, ZH1 618, CSA 22.2 No. 950, RoHS, WEEE
Power adapter
Nominal Voltage
Power Provided
85 Watt
Operating System / Software
OS Provided
OS Certified
Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Microsoft Windows Server 2003 Terminal Server, Microsoft Windows Server 2008 Terminal Server, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenDesktop 4, Citrix XenApp 5, Citrix XenApp 6
Software
Microsoft Firewall, HP Universal Print Driver, HP ThinState Tools, HP Connection Manager, HP Easy Tools, File Based Write Filter, Enhanced Write Filter, Microsoft Internet Explorer 9.0, Microsoft RDP 7.1, HP Device Manager Agent, VMware View 5.0, HP TeemTalk Terminal Emulator 7.3
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
6.5 cm
22 cm
24 cm
1.98 kg
10 °C
10 - 90% (non-condensing)
HP T610 Plus WES7P 16SF/4GR ES TC Bundle deal on HP T610 Plus WES7P 16SF/4GR ES TC
£679.36
saving £8.33
£596.37
Storage Type: Flash
Processor Model: T56N
Type: Thin client
Case Style: Tower
Display: no
Optical Storage: None
Brand: HP
Price Range Ex VAT: 300 - 500
