HP t610 Flexible Thin Client delivers added security, broad expansion options and a PC-like multimedia experience for virtualized desktops. A flexible solution with a powerful boost in performance.
Advanced technology, high-end deployment
AMD's APU technology, combining dual core processor with AMD HD 6320 graphics. Features DirectX 11 graphics support, DDR3-1600 RAM and DVI-I and DisplayPort outputs. -
A flexible PC-alternative
The HP t610 PLUS (larger chassis, expansion card bay and added legacy ports) feature 6 USB ports: 2 USB 3.0 ports, 4 USB 2.0 ports, and PS/2 legacy ports, as well as serial and parallel ports. -
Eco-highlights
HP t610 Flexible Series Thin Client is built with the environment in mind.
- HP Flexible t610 PLUS - tower - G-T56N 1.65 GHz - 4 GB - flash 16 GB
- Thin client - tower
- Localisation
- Processor
- 1 x AMD G-T56N 1.65 GHz (Dual-Core)
- Cache Memory
- 1 MB L2 Cache
- Cache Per Processor
- 1 MB
- RAM
- 4 GB (installed) / 4 GB (max) - DDR3 SDRAM
- Hard Drive
- Flash 16 GB
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon HD 6320
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows Embedded Standard 7P
- Software Included
- Microsoft Firewall, HP Universal Print Driver, HP ThinState Tools, HP Connection Manager, HP Easy Tools, File Based Write Filter, Enhanced Write Filter, Microsoft Internet Explorer 9.0, Microsoft RDP 7.1, HP Device Manager Agent, VMware View 5.0, HP TeemTalk Terminal Emulator 7.3
- 6.5 cm x 22 cm x 24 cm
- 1.98 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - 3 years
- Thin client
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Tower
- Localisation
Processor / Chipset
- CPU
- AMD G-T56N
- Clock Speed
- 1.65 GHz
- Number of Cores
- Dual-Core
- 64-bit Computing
- CPU Qty
- 1
- Chipset Type
- AMD A55E
Cache Memory
- Installed Size
- L2 Cache - 1 MB
- 1 MB
RAM
- Installed Size
- 4 GB / 4 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total)
Hard Drive
- Flash
- Capacity
- 16 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DVI, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 44 kHz
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Standard Keyboard
- Interface
- PS/2
Mouse
- Technology
- Optical
- Interface
- PS/2
- Data Link Protocol
- Wake on LAN (WoL), DHCP support, PXE support
- Slots
- 2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe x16 - low-profile (x4 mode)
- 4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 , 1 x DVI-I , 1 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in/microphone (1 in front) , 1 x audio line-out/headphones (1 in front)
- Cables Included
- DVI-VGA adapter
- Theft/Intrusion Protection
- FCC Class B certified, TUV GS, VCCI, EN55022, UL 1950, ZH1 618, CSA 22.2 No. 950, RoHS, WEEE
- Power adapter
- Voltage Required
- Power Provided
- 85 Watt
Operating System / Software
- OS Provided
- OS Certified
- Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Microsoft Windows Server 2003 Terminal Server, Microsoft Windows Server 2008 Terminal Server, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenDesktop 4, Citrix XenApp 5, Citrix XenApp 6
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 6.5 cm
- 22 cm
- 24 cm
- 1.98 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
