HP t610 PLUS Flexible Thin Client Dual-Core T56N 4GB
Quicklinx: 8SVZWS00 Mfr#: B8D15AA#ABU
HP t610 Flexible Thin Client delivers added security, broad expansion options and a PC-like multimedia experience for virtualized desktops. A flexible solution with a powerful boost in performance.
  • Advanced technology, high-end deployment
    AMD's APU technology, combining dual core processor with AMD HD 6320 graphics. Features DirectX 11 graphics support, DDR3-1600 RAM and DVI-I and DisplayPort outputs.
  • A flexible PC-alternative
    The HP t610 PLUS (larger chassis, expansion card bay and added legacy ports) feature 6 USB ports: 2 USB 3.0 ports, 4 USB 2.0 ports, and PS/2 legacy ports, as well as serial and parallel ports.
  • Eco-highlights
    HP t610 Flexible Series Thin Client is built with the environment in mind.
HP Flexible t610 PLUS - tower - G-T56N 1.65 GHz - 4 GB - flash 16 GB
Thin client - tower
1 x AMD G-T56N 1.65 GHz (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 4 GB (max) - DDR3 SDRAM
Hard Drive
Flash 16 GB
Optical Storage
No optical drive
Graphics Controller
AMD Radeon HD 6320
Audio Output
Stereo - integrated
1GbE
OS Provided
Microsoft Windows Embedded Standard 7P
Software Included
Microsoft Firewall, HP Universal Print Driver, HP ThinState Tools, HP Connection Manager, HP Easy Tools, File Based Write Filter, Enhanced Write Filter, Microsoft Internet Explorer 9.0, Microsoft RDP 7.1, HP Device Manager Agent, VMware View 5.0, HP TeemTalk Terminal Emulator 7.3
6.5 cm x 22 cm x 24 cm
1.98 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - 3 years
Thin client
Recommended Use
Small business, corporate business
Product Form Factor
Tower
Processor / Chipset
CPU
AMD G-T56N
Clock Speed
1.65 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Chipset Type
AMD A55E
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 4 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
SO-DIMM 204-pin
Slots
2 (Total)
Hard Drive
Flash
16 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 6320
Video Interfaces
VGA, DVI, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
44 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
PS/2
Mouse
Optical
PS/2
Wake on LAN (WoL), DHCP support, PXE support
Slots
2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe x16 - low-profile (x4 mode)
4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 , 1 x DVI-I , 1 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x serial , 1 x parallel , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in/microphone (1 in front) , 1 x audio line-out/headphones (1 in front)
DVI-VGA adapter
Theft/Intrusion Protection
FCC Class B certified, TUV GS, VCCI, EN55022, UL 1950, ZH1 618, CSA 22.2 No. 950, RoHS, WEEE
Power adapter
Power Provided
85 Watt
Operating System / Software
OS Provided
OS Certified
Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Microsoft Windows Server 2003 Terminal Server, Microsoft Windows Server 2008 Terminal Server, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenDesktop 4, Citrix XenApp 5, Citrix XenApp 6
Software
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
6.5 cm
22 cm
24 cm
1.98 kg
10 °C
10 - 90% (non-condensing)
