Transition your fleet to the cloud with the HP t540 Thin Client virtual desktop solution. Confidently deploy in confined workspaces with multiple configuration options and multi-layered security-providing effective collaboration and productivity for the end user.
Modern flexibility
Set it. Mount it. Stand it. Conveniently position the thin client in up to six different orientations with a VESA mount. -
Engineered to last
Rely on the built-in durability of the HP t540 Thin Client, with 120,000 hours of testing, utilizing the HP Total Test Process. Keep up with extended hours of use over a prolonged period-reducing downtime and maintaining business performance. -
Neutralize threats and keep data safe and secure
Defend against cold-boot attacks with AMD Memory Guard. Full memory encryption protects at the component level, offsetting threats to sensitive data. -
Protect your fleet with device security for resiliency and recovery
Protect device firmware from bootup to shut down with the UEFI Secure Boot. HP t540 Thin Client firmware implements NIST SP800-147 and SP800-155 integrity measurement guidelines. -
Make IT management and security a breeze
Ease the burden of IT admins in Windows environments with HP Write Manager, a simple write filter solution that works across multiple Windows versions and prevents unauthorized changes to end user environments. -
Secure your device with a cable lock slot
Deter device theft in public environments with an integrated cable lock slot and physically lock down your device, assuring IT's peace of mind.
- HP t540 - USFF Ryzen Embedded R1305G 1.5 GHz - 4 GB - flash 32 GB - UK - TAA Compliant
- Thin client - USFF
- Localisation
- Processor
- 1 x AMD Ryzen Embedded R1305G / 1.5 GHz (up to 2.8 GHz, (Dual-Core)
- Cache Memory
- 4 MB L3 Cache
- Cache Per Processor
- 4 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC
- Hard Drive
- Flash 32 GB - eMMC
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon Vega 3
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0, Wi-Fi 6
- Keyboard
- UK
- Power
- (50/60 Hz)
- OS Provided
- HP ThinPro
- Software Included
- HP Easy Tools, HP Device Manager, HP Smart Zero Client Services
- 3.5 cm x 20 cm x 20 cm
- 969 g
- TAA Compliant
- Environmental Standards
- TCO Certified Desktops 9, ENERGY STAR Qualified EPEAT Silver
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- USFF
- Localisation
Processor / Chipset
- CPU
- AMD Ryzen Embedded R1305G
- Clock Speed
- 1.5 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- L2 cache
- 2 x 512 KB
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L3 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 1 (Total) / 0 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- Flash - eMMC
- Capacity
- 1 x 32 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon Vega 3
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 2
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP USB Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111HSH
- Wireless LAN Supported
- Wireless NIC
- Intel Wi-Fi 6 AX 200
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0, IEEE 802.11ax (Wi-Fi 6)
- Dual stream (2x2)
- IEEE 802.1x
- Slots
- 1 (total) / 0 (free) x M.2 Card (for internal storage)
- 1 x USB 3.1 Gen 1 (1 in front) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x headphones/microphone (1 in front) , 2 x USB 3.1 Gen 2 , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) - RJ-45 , 2 x DisplayPort 1.2
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, UL, BSMI, GS, CB, CCC, ICES Class B, WEEE, KCC Class B, AS/NZS, ERP, CECP, RoHS2, VCCI Class B, CP65, CISPR Class B, SEPA, low halogen, HP GSE, EN, CNS, IEEE 1680.1
- TAA Compliant
- Power adapter
- Power Device Name
- HP Smart AC Adapter
- Voltage Required
- AC 115/230 V (50/60 Hz)
- Power Provided
- 45 Watt
Operating System / Software
- OS Provided
- HP ThinPro
- Software
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 3.5 cm
- 20 cm
- 20 cm
- 969 g
- Shipping Weight
- 2.879 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
Warranties (4)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only | In Stock | £24.71 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years | In Stock | £48.26 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment | In Stock | £36.49 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year | In Stock | £17.66 |
Monitors (2)
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £138.54 |
HP P34hc G4 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £373.33 |
Keyboards and Mice (3)
HP 128 Wired Mouse | In Stock | £10.20 |
HP Desktop 320MK Keyboard and Mouse Set - UK Input Device | In Stock | £29.47 |
HP 655 Keyboard and Mouse Set - Wireless | In Stock | £36.21 |
Other bundles (7)
HPE DisplayPort DVI-D Adapter | In Stock | £11.65 |
HPE DisplayPort to VGA Adapter | In Stock | £13.20 |
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP Business Slim Keyboard with Smart reader | In Stock | £48.79 |
HP USB-C TO RJ45 Adapter | In Stock | £179.67 |
HP USB-C LC Power Adapter - 65 Watt | In Stock | £15.28 |
Poly EncorePro 525 USB EP525-M USB-A Headset | In Stock | £42.60 |
