HP T540 Thin Client AMD Ryzen R1305G 8GB 64GB eMMC Windows 10 IoT Enterprise
Quicklinx: GQVFWS00 Mfr#: 12H33EA#ABU
Transition your fleet to the cloud with the HP t540 Thin Client virtual desktop solution. Confidently deploy in confined workspaces with multiple configuration options and multi-layered security-providing effective collaboration and productivity for the end user.
  • Modern flexibility
    Set it. Mount it. Stand it. Conveniently position the thin client in up to six different orientations with a VESA mount.
  • Engineered to last
    Rely on the built-in durability of the HP t540 Thin Client, with 120,000 hours of testing, utilizing the HP Total Test Process. Keep up with extended hours of use over a prolonged period-reducing downtime and maintaining business performance.
  • Neutralize threats and keep data safe and secure
    Defend against cold-boot attacks with AMD Memory Guard. Full memory encryption protects at the component level, offsetting threats to sensitive data.
  • Protect your fleet with device security for resiliency and recovery
    Protect device firmware from bootup to shut down with the UEFI Secure Boot. HP t540 Thin Client firmware implements NIST SP800-147 and SP800-155 integrity measurement guidelines.
  • Make IT management and security a breeze
    Ease the burden of IT admins in Windows environments with HP Write Manager, a simple write filter solution that works across multiple Windows versions and prevents unauthorized changes to end user environments.
  • Secure your device with a cable lock slot
    Deter device theft in public environments with an integrated cable lock slot and physically lock down your device, assuring IT's peace of mind.
HP t540 - USFF Ryzen Embedded R1305G 1.5 GHz - 8 GB - flash 64 GB - UK
Thin client - USFF
1 x AMD Ryzen Embedded R1305G / 1.5 GHz (up to 2.8 GHz, (Dual-Core)
Cache Memory
4 MB L3 Cache
Cache Per Processor
4 MB
RAM
8 GB (installed) / 16 GB (max) - DDR4 SDRAM
Hard Drive
Flash 64 GB - eMMC
Optical Storage
No optical drive
Graphics Controller
AMD Radeon Vega 3
1GbE
Keyboard
(50/60 Hz)
OS Provided
Windows 10 IoT Enterprise for Thin Clients
3.5 cm x 20 cm x 20 cm
1.4 kg
Environmental Standards
TCO Certified Desktops 9, ENERGY STAR Qualified EPEAT Silver
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
USFF
Embedded Security
Trusted Platform Module (TPM) Security Chip
Processor / Chipset
CPU
Clock Speed
1.5 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
L2 cache
2 x 512 KB
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L3 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
1 (Total) / 0 (empty)
Configuration Features
1 x 8 GB
Hard Drive
Flash - eMMC
1 x 64 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon Vega 3
Video Interfaces
DisplayPort
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP USB Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111HSH
Slots
1 M.2 Card
3 x USB 3.1 Gen 1 (1 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 (2 rear) , Headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
UL, VCCI, BSMI, GS, CB, CCC, FCC, KCC, WEEE, CISPR, ICES, ERP, CECP, RoHS2, SEPA, low halogen, EN
Power adapter
Power Provided
45 watt
Operating System / Software
OS Provided
Windows 10 IoT Enterprise for Thin Clients English
OS Certified
HP ThinPro, HP Smart Zero Core, Windows 10 IoT Enterprise 2019 LTSC
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
3.5 cm
20 cm
20 cm
1.4 kg
Shipping Weight
2.879 kg
10 °C
Warranties (6)
GQVF HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only In Stock £25.23
GQVF HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years In Stock £49.26
GQVF HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment In Stock £37.24
GQVF HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year In Stock £18.01
GQVF HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £33.64
Monitors (1)
GQVF HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £157.60
Keyboards and Mice (3)
GQVF HP 128 Wired Mouse In Stock £8.49
GQVF HP Desktop 320MK - Keyboard and mouse set - full size - USB - UK - black In Stock £15.34
GQVF HP 320K Wired Keyboard In Stock £11.79
Other bundles (5)
GQVF HPE DisplayPort DVI-D Adapter In Stock £19.88
GQVF HPE DisplayPort to VGA Adapter In Stock £13.22
GQVF HP USB-C To VGA Adapter In Stock £23.07
GQVF HP USB-C LC Power Adapter - 65 Watt In Stock £15.09
GQVF Poly EncorePro 525 USB EP525 USB-A Headset In Stock £90.57
