HP T530 Thin Client AMD GX-215JJ 4GB 128GB Windows 10 Pro
Quicklinx: DX0HWS00 Mfr#: Y5X65EA#ABU
Upgrade your cloud computing environment with the first HP thin client made for the office of the future. Elegantly designed with essential performance and reliability, the HP t530 Thin Client meets the needs of today and the growing demands of tomorrow.
  • Elevate your office space
    The HP t530 has raised the stakes for thin client design. Get all the features you need in an exceptionally modern, compact device. And with quiet, solid-state operation and multiple deployment options, it fits perfectly into any workspace.
  • Handle cloud computing workloads with ease
    Easily tackle all your computing demands with the newest AMD thin client technology. Whether doing offloaded processing or graphics rendering, you'll get an amazing PC-like experience in the cloud.
  • Future proof your office
    Finally a thin client built for today and tomorrow. Packed with flash storage, memory and connectivity options, along with multiple ports including USB-C to support both old and new peripherals, your transition into the future will be seamless..
HP t530 - tower GX-215JJ 1.5 GHz - 4 GB - flash 128 GB
Thin client - tower
1 x AMD GX-215JJ 1.5 GHz (up to 2 GHz, (Dual-Core)
Processor Main Features
AMD Turbo CORE Technology
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Hard Drive
Flash 128 GB - M.2
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R2E
1GbE
OS Provided
Windows 10 IoT Enterprise
3.5 cm x 20 cm x 20 cm
962.8 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
AMD GX-215JJ
Clock Speed
1.5 GHz
Max Turbo Speed
2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Slots
1 (Total) / 0 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
Flash - M.2
1 x 128 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R2E
Wake on LAN (WoL), DHCP support, PXE support
Slots
1 (total) / 0 (free) x M.2 Card
3 x USB 3.1 Gen 1 (1 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 , Headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, CISPR, ICES, MEPS, ERP, CECP, EMI, low halogen
Power adapter
Power Provided
45 Watt
Operating System / Software
OS Provided
Windows 10 IoT Enterprise English
Sustainability Information
ENERGY STAR Certified
3.5 cm
20 cm
20 cm
962.8 g
10 °C
10 - 90% (non-condensing)
Warranties (4)
DX0H HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only In Stock £25.23
DX0H HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years In Stock £49.26
DX0H HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment In Stock £37.24
DX0H HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year In Stock £18.01
Other bundles (2)
DX0H HPE DisplayPort DVI-D Adapter In Stock £19.77
DX0H HPE DisplayPort to VGA Adapter In Stock £13.14
