Upgrade your cloud computing environment with the first HP thin client made for the office of the future. Elegantly designed with essential performance and reliability, the HP t530 Thin Client meets the needs of today and the growing demands of tomorrow.
Elevate your office space
The HP t530 has raised the stakes for thin client design. Get all the features you need in an exceptionally modern, compact device. And with quiet, solid-state operation and multiple deployment options, it fits perfectly into any workspace. -
Handle cloud computing workloads with ease
Easily tackle all your computing demands with the newest AMD thin client technology. Whether doing offloaded processing or graphics rendering, you'll get an amazing PC-like experience in the cloud. -
Future proof your office
Finally a thin client built for today and tomorrow. Packed with flash storage, memory and connectivity options, along with multiple ports including USB-C to support both old and new peripherals, your transition into the future will be seamless..
- HP t530 - tower GX-215JJ 1.5 GHz - 8 GB - flash 32 GB
- Thin client - tower
- Localisation
- Processor
- 1 x AMD GX-215JJ 1.5 GHz (up to 2 GHz, (Dual-Core)
- Processor Main Features
- AMD Turbo CORE Technology
- Cache Memory
- 1 MB L2 Cache
- Cache Per Processor
- 1 MB
- RAM
- 8 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC
- Hard Drive
- Flash 32 GB - M.2
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R2E
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 IoT Enterprise
- 3.5 cm x 20 cm x 20 cm
- 962.8 g
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD GX-215JJ
- Clock Speed
- 1.5 GHz
- Max Turbo Speed
- 2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L2 Cache - 1 MB
- 1 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 1866 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 1 (Total) / 0 (empty)
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 32 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R2E
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 2
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- Wake on LAN (WoL), DHCP support, PXE support
- IEEE 802.1x
- Slots
- 1 (total) / 0 (free) x M.2 Card
- 3 x USB 3.1 Gen 1 (1 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 (2 rear) , Headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, CISPR, ICES, MEPS, ERP, CECP, EMI, low halogen
- Power adapter
- Voltage Required
- Power Provided
- 45 Watt
Operating System / Software
- OS Provided
- Windows 10 IoT Enterprise English
- OS Certified
- HP ThinPro, Microsoft Windows Embedded Standard 7E, HP Smart Zero Core, Windows 10 IoT Enterprise
Sustainability Information
- ENERGY STAR Certified
- 3.5 cm
- 20 cm
- 20 cm
- 962.8 g
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
Warranties (4)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only | In Stock | £24.71 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years | In Stock | £48.26 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment | In Stock | £36.49 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year | In Stock | £18.70 |
Monitors (1)
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £235.36 |
