HP T530 AMD Radeon GX-215JJ 4GB 8GB Thin Client
Quicklinx: DZBYWS00 Mfr#: 2RC30EA#ABU
Processor Type: GX-215JJ
Operating System: HP ThinPro
Installed Memory: 4GB
Hard Drive Capacity: 8GB
Storage Type: Flash
£339.59 ex VAT
£407.50 inc VAT
Upgrade your cloud computing environment with the first HP thin client made for the office of the future. Elegantly designed with essential performance and reliability, the HP t530 Thin Client meets the needs of today and the growing demands of tomorrow.
  • Elevate your office space
    The HP t530 has raised the stakes for thin client design. Get all the features you need in an exceptionally modern, compact device. And with quiet, solid-state operation and multiple deployment options, it fits perfectly into any workspace.
  • Handle cloud computing workloads with ease
    Easily tackle all your computing demands with the newest AMD thin client technology. Whether doing offloaded processing or graphics rendering, you'll get an amazing PC-like experience in the cloud.
  • Future proof your office
    Finally a thin client built for today and tomorrow. Packed with flash storage, memory and connectivity options, along with multiple ports including USB-C to support both old and new peripherals, your transition into the future will be seamless..
HP t530 - tower - GX-215JJ 1.5 GHz - 4 GB - 8 GB
Thin client - tower
1 x AMD GX-215JJ 1.5 GHz (2 GHz) (Dual-Core)
Processor Main Features
AMD Turbo CORE Technology
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900
Hard Drive
1 x flash 8 GB - M.2 - multi-level cell (MLC)
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R2E
GigE
OS Provided
HP ThinPro
3.5 cm x 20 cm x 20 cm
962.8 g
Thin client
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1866 MHz
Rated Memory Speed
1866 MHz
Memory Specification Compliance
PC4-14900
SO-DIMM 260-pin
Slots
1 (Total) / 0 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
Flash - M.2
1 x 8 GB
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R2E
Video Interfaces
DisplayPort
Max Monitors Supported
2
Wake on LAN (WoL), DHCP support, PXE support
IEEE 802.1x
Slots
1 (total) / 0 (free) x M.2 Card
1 x USB-C 3.1 Gen 1 (1 in front) , 3 x USB 3.1 Gen 1 (1 front, 2 rear) , 2 x USB 2.0 , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , Headphones/microphone (1 in front)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, CISPR, ICES, MEPS, ERP, CECP, EMI
Power adapter
Nominal Voltage
Power Provided
45 Watt
Operating System / Software
OS Provided
HP ThinPro
3.5 cm
20 cm
20 cm
962.8 g
10 °C
10 - 90% (non-condensing)
HP T530 AMD Radeon GX-215JJ 4GB 8GB Thin Client Bundle deal on HP T530 AMD Radeon GX-215JJ 4GB 8GB Thin Client
£438.76
Storage Type: Flash
Type: Thin client
Case Style: Tower
Display: not included
Optical Storage: None
Brand: HP
Price Range Ex VAT: 300 - 500
