Upgrade your cloud computing environment with the first HP thin client made for the office of the future. Elegantly designed with essential performance and reliability, the HP t530 Thin Client meets the needs of today and the growing demands of tomorrow.
The next-generation thin client
Introducing incredible durability engineered around an AMD GX-215JJ dual-core 1.5 – 2.0 GHz SoC with Radeon R2E graphics and a fully solid-state fan-less design. Welcome to a future-focused desktop thin client experience. -
Protection against system threats
Security and performance go hand in hand with newly designed embedded operating systems and Trusted Platform Module hardware. Virtualized cloud computing ensures against system threats. -
Support from every angle
Support comes naturally when you have a choice of USB ports, including USB-C , serial and VGA ports. And with two DisplayPort outputs, we've got support covered, from every angle. -
Stay connected
With an embedded GbE network adapter and optional Wi-Fi adapter with Bluetooth and choice of internal or external antenna systems, connectivity is covered to meet your every need and deployment scenario. -
Memory to serve your needs
With solid-state flash memory storage options up to 512 GB, and SDRAM system memory up to 16 GB, performance is assured now and in the future. -
Choose your favorite OS
Now you can choose between a Windows operating system or HP's ThinPro with Smart Zero Core. These operating systems enable connecting to your own ISV with Citrix , VMware , and Microsoft , or let you go straight to the Cloud with included browsers.
- HP t530 - tower GX-215JJ 1.5 GHz - 4 GB - flash 32 GB
- Thin client - tower
- Localisation
- Processor
- 1 x AMD GX-215JJ 1.5 GHz (, up to 2 GHz, (Dual-Core)
- Processor Main Features
- AMD Turbo CORE Technology
- Cache Memory
- 1 MB L2 Cache
- Cache Per Processor
- 1 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900
- Hard Drive
- Flash 32 GB - M.2
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R2E
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 IoT Enterprise
- 3.5 cm x 20 cm x 20 cm
- 962.8 g
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD GX-215JJ
- Clock Speed
- 1.5 GHz
- Max Turbo Speed
- 2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L2 Cache - 1 MB
- 1 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 1866 MHz
- Memory Specification Compliance
- PC4-14900
- Form Factor
- SO-DIMM 260-pin
- Slots
- 1 (Total) / 0 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- Flash - M.2
- Capacity
- 1 x 32 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R2E
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 2
Input Device
- Mouse
Mouse
- Technology
- Optical
- Interface
- USB
- Data Link Protocol
- Wake on LAN (WoL), DHCP support, PXE support
- IEEE 802.1x
- Slots
- 1 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card
- 3 x USB 3.1 Gen 1 (1 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 (2 rear) , Headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, CISPR, ICES, MEPS, ERP, CECP, EMI, low halogen
- Power adapter
- Voltage Required
- Power Provided
- 45 Watt
Operating System / Software
- OS Provided
- Windows 10 IoT Enterprise English
- OS Certified
- HP ThinPro, Microsoft Windows Embedded Standard 7E, HP Smart Zero Core, Windows 10 IoT Enterprise
Sustainability Information
- ENERGY STAR Certified
- 3.5 cm
- 20 cm
- 20 cm
- 962.8 g
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only | In Stock | £24.71 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years | In Stock | £48.26 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment | In Stock | £36.49 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year | In Stock | £18.70 |
