HP T530 AMD Radeon GX-215JJ 4GB 16GB Thin Client
Quicklinx: DZBVWS00 Mfr#: 2RC25EA#ABU
  • IEEE 802.11n
Upgrade your cloud computing environment with the first HP thin client made for the office of the future. Elegantly designed with essential performance and reliability, the HP t530 Thin Client meets the needs of today and the growing demands of tomorrow.
  • The next-generation thin client
    Introducing incredible durability engineered around an AMD GX-215JJ dual-core 1.5 – 2.0 GHz SoC with Radeon R2E graphics and a fully solid-state fan-less design. Welcome to a future-focused desktop thin client experience.
  • Protection against system threats
    Security and performance go hand in hand with newly designed embedded operating systems and Trusted Platform Module hardware. Virtualized cloud computing ensures against system threats.
  • Support from every angle
    Support comes naturally when you have a choice of USB ports, including USB-C , serial and VGA ports. And with two DisplayPort outputs, we've got support covered, from every angle.
  • Stay connected
    With an embedded GbE network adapter and optional Wi-Fi adapter with Bluetooth and choice of internal or external antenna systems, connectivity is covered to meet your every need and deployment scenario.
  • Memory to serve your needs
    With solid-state flash memory storage options up to 512 GB, and SDRAM system memory up to 16 GB, performance is assured now and in the future.
  • Choose your favorite OS
    Now you can choose between a Windows operating system or HP's ThinPro with Smart Zero Core. These operating systems enable connecting to your own ISV with Citrix , VMware , and Microsoft , or let you go straight to the Cloud with included browsers.
HP t530 - tower - GX-215JJ 1.5 GHz - 4 GB - flash 16 GB
Thin client - tower
1 x AMD GX-215JJ 1.5 GHz (, up to 2 GHz, (Dual-Core)
Processor Main Features
AMD Turbo CORE Technology
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC - PC4-14900
Hard Drive
Flash 16 GB - M.2
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R2E
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
OS Provided
Microsoft Windows Embedded Standard 7E 32-bit
3.5 cm x 20 cm x 20 cm
962.8 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
AMD GX-215JJ
Clock Speed
1.5 GHz
Max Turbo Speed
2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1866 MHz
Rated Memory Speed
1866 MHz
Memory Specification Compliance
PC4-14900
SO-DIMM 260-pin
Slots
1 (Total) / 0 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
Flash - M.2
1 x 16 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R2E
Video Interfaces
DisplayPort
Max Monitors Supported
2
Input Device
Mouse
Mouse
Optical
USB
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Wake on LAN (WoL), DHCP support, PXE support
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Slots
1 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card
3 x USB 3.1 Gen 1 (1 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 (2 rear) , Headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, CISPR, ICES, MEPS, ERP, CECP, EMI, low halogen
Power adapter
Power Provided
45 Watt
Operating System / Software
OS Provided
Microsoft Windows Embedded Standard 7E 32-bit English
OS Certified
HP ThinPro, Microsoft Windows Embedded Standard 7E, HP Smart Zero Core, Windows 10 IoT Enterprise
Sustainability Information
ENERGY STAR Certified
3.5 cm
20 cm
20 cm
962.8 g
10 °C
10 - 90% (non-condensing)
Warranties (4)
DZBV HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only In Stock £25.29
DZBV HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years In Stock £49.36
DZBV HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment In Stock £37.31
DZBV HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year In Stock £18.06
Monitors (2)
DZBV HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
DZBV HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £150.00
Other bundles (3)
DZBV HPE DisplayPort To VGA Adapter In Stock £13.72
DZBV HPE DisplayPort DVI-D Adapter In Stock £13.23
DZBV HPE DisplayPort to VGA Adapter In Stock £16.40
