Get a flexible, reliable desktop experience for your virtual network and knowledge base users with the HP t520 Flexible Thin Client.
Essential business performance
Get the best bang for your investment buck with AMD GX-212JC SOC (System on Chip), HD graphics, and expansive memory and storage. -
Place it where you need it
Make the most of your available workspace and deploy the sleek, new, fanless chassis horizontally or vertically in a range of compact settings. -
Keep it simple
Make it easy to deploy, manage, and maintain your install base with HP Device Manager, a software tool available exclusively for HP Thin Clients. -
High quality LAN-like data delivery
Improve network performance and the end-user experience with HP Velocity software. -
Get the right OS for your environment and budget
Select a Windows OS for a familiar Windows experience with Enhanced Write Filter security and added multi-touch support, HP ThinPro for full-featured Linux or HP Smart Zero Technology for simple management. -
No-hassle virtualization
Connect to your virtualized desktops and applications with support for the latest ISVs and certifications from Citrix, VMware, and Microsoft.
- HP Flexible t520 - tower - GX-212JC 1.2 GHz - 4 GB - SSD 8 GB
- Thin client - tower
- Localisation
- Processor
- 1 x AMD GX-212JC 1.2 GHz (Dual-Core)
- Cache Memory
- 1 MB L2 Cache
- Cache Per Processor
- 1 MB
- RAM
- 4 GB (installed) / 8 GB (max) - DDR3L SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA
- Hard Drive
- SSD 8 GB - SATA - M.2
- Optical Storage
- No optical drive
- Audio Output
- Integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- HP ThinPro 32-bit
- Software Included
- Citrix ICA, Microsoft RDP, HP ThinState Tools, HP Easy Tools, HP Device Manager, VMware Horizon View, Citrix HDX, Microsoft RemoteFX, Mozilla Firefox 19
- 4.51 cm x 20 cm x 20.01 cm
- 1.04 kg
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- Tower
- Localisation
Processor / Chipset
- CPU
- AMD GX-212JC
- Clock Speed
- 1.2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- L2 Cache - 1 MB
- 1 MB
RAM
- Installed Size
- 4 GB / 8 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 1 (Total) / 0 (empty)
- Unbuffered, low-voltage
- Configuration Features
- 1 x 4 GB
Hard Drive
- SSD - M.2
- Capacity
- 1 x 8 GB
- Interface Type
- SATA
- Multi-level cell (MLC)
Storage Controller
- 1 x SATA - integrated
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Standard Keyboard
- Interface
- USB
Mouse
- Technology
- Optical
- Interface
- USB
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Slots
- 1 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe Half Mini Card
- 2 x USB 3.0 (2 in front) , 4 x USB 2.0 , 2 x DisplayPort , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out/headphones - mini-jack (1 in front) , 1 x audio line-in/microphone - mini-jack (1 in front)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- TUV GS, VCCI, UL 1950, EN55022 Class B, FCC, RoHS, low halogen
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- HP ThinPro 32-bit
- Software
- 4.51 cm
- 20 cm
- 20.01 cm
- 1.04 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 12.9 dBA
