Optimized for desktop virtualization and cloud-based applications, the intuitive HP t430 Thin Client is easy for end users to understand and simple for IT administrators to maintain.
New, user-friendly experience
Whether you choose the Linux based HP ThinPro or Windows 10 IoT option, users will get an intuitive, natural interface and familiar navigation. -
Nimble design to blend in or stand out
Designed with a sleeker profile and built-in VESA mount, the HP t430 Thin Client can be mounted on the back of a display or placed discreetly on or under a desk or in a kiosk. -
Plenty of power and high-definition graphics
Get more than enough performance for all your tasks with the latest-generation Intel Celeron processor with speeds up to 2.8 GHz, DDR4 memory, solid-state storage, and support for a 4K display. -
Powerful connections that do more
Connect instantly with Citrix , VMware , Microsoft RDP, and default web browsers right out of the box. Communicate and collaborate with support for Skype for Business and Cisco VXME. -
Provide flexibility with a full range of connectivity
Add your devices and displays and connect to your network with input/output ports that include USB-C , DisplayPort , HDMI, and LAN or optional Wi-Fi with integrated adapters and antennas. -
Easily access the applications you need
- HP t430 - DTS Celeron N4000 1.1 GHz - 4 GB - flash 16 GB
- Thin client - DTS
- Localisation
- Processor
- 1 x Intel Celeron N4000 / 1.1 GHz (, up to 2.6 GHz, (Dual-Core)
- Processor Main Features
- Intel Burst Technology
- Cache Memory
- 4 MB
- Cache Per Processor
- 4 MB
- RAM
- 4 GB DDR4 SDRAM
- Hard Drive
- Flash 16 GB - eMMC
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 600
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- HP ThinPro
- 13.5 cm x 13.5 cm x 3.2 cm
- 410 g
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- TCO Certified Desktops 9, ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Thin client
- Product Form Factor
- DTS
- Localisation
Processor / Chipset
- CPU
- Intel Celeron N4000
- Clock Speed
- 1.1 GHz
- Max Turbo Speed
- 2.6 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 4 MB
- 4 MB
RAM
- Installed Size
- 4 GB
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Configuration Features
- Provided memory is soldered
Hard Drive
- Flash - eMMC
- Capacity
- 1 x 16 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Interface (Bus) Type
- M.2 Card
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- 1 x DisplayPort/USB-C 3.1 Gen 1 , USB 2.0 , 1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone , 2 x USB 3.1 Gen 1
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- HP Smart Buy
- Power adapter
- Voltage Required
- Power Provided
- 45 Watt
Operating System / Software
- OS Provided
- HP ThinPro English
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 13.5 cm
- 13.5 cm
- 3.2 cm
- 410 g
- Shipping Weight
- 1.27 kg
Warranties (4)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only | In Stock | £24.71 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years | In Stock | £48.26 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment | In Stock | £36.49 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year | In Stock | £18.70 |
Other bundles (7)
HPE DisplayPort DVI-D Adapter | In Stock | £19.74 |
HPE DisplayPort to VGA Adapter | In Stock | £13.12 |
HPE USB to Serial Port Adapter | In Stock | £13.94 |
APC BACK-UPS BE650G2-UK 650VA 230V | In Stock | £109.43 |
APC BACK-UPS BE850G2-UK 850VA 230V USB | In Stock | £121.59 |
APC BACK UPS PRO BR650MI 650VA 6 Outlets | In Stock | £152.02 |
APC BACK UPS PRO BR900MI 900VA 6 Outlets | In Stock | £209.65 |
