HP T430 Celeron N400 32GB Thin Client
Quicklinx: DZTJWS00 Mfr#: 3VL71AA#ABU
  • Celeron
Optimized for desktop virtualization and cloud-based applications, the intuitive HP t430 Thin Client is easy for end users to understand and simple for IT administrators to maintain.
  • New, user-friendly experience
    Whether you choose the Linux based HP ThinPro or Windows 10 IoT option, users will get an intuitive, natural interface and familiar navigation.
  • Nimble design to blend in or stand out
    Designed with a sleeker profile and built-in VESA mount, the HP t430 Thin Client can be mounted on the back of a display or placed discreetly on or under a desk or in a kiosk.
  • Plenty of power and high-definition graphics
    Get more than enough performance for all your tasks with the latest-generation Intel Celeron processor with speeds up to 2.8 GHz, DDR4 memory, solid-state storage, and support for a 4K display.
  • Powerful connections that do more
    Connect instantly with Citrix , VMware , Microsoft RDP, and default web browsers right out of the box. Communicate and collaborate with support for Skype for Business and Cisco VXME.
  • Provide flexibility with a full range of connectivity
    Add your devices and displays and connect to your network with input/output ports that include USB-C , DisplayPort , HDMI, and LAN or optional Wi-Fi with integrated adapters and antennas.
  • Easily access the applications you need
HP t430 - DTS Celeron N4000 1.1 GHz - 4 GB - flash 32 GB
Thin client - DTS
1 x Intel Celeron N4000 / 1.1 GHz (up to 2.6 GHz, (Dual-Core)
Processor Main Features
Intel Burst Technology
Cache Memory
4 MB
Cache Per Processor
4 MB
RAM
4 GB DDR4 SDRAM
Hard Drive
Flash 32 GB - eMMC
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 600
1GbE
OS Provided
Windows 10 IoT Enterprise 64-bit Edition
13.5 cm x 13.5 cm x 3.2 cm
410 g
Environmental Standards
TCO Certified Desktops 9, ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
DTS
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Intel Celeron N4000
Clock Speed
1.1 GHz
Max Turbo Speed
2.6 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
4 MB
Cache Per Processor
4 MB
RAM
Installed Size
4 GB
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Configuration Features
Provided memory is soldered
Hard Drive
Flash - eMMC
1 x 32 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
1 x DisplayPort/USB-C 3.1 Gen 1 , 3 x USB - Type A , 1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
Power adapter
Power Provided
45 Watt
Operating System / Software
OS Provided
Windows 10 IoT Enterprise 64-bit Edition English
Sustainability Information
TCO Certified
ENERGY STAR Certified
13.5 cm
13.5 cm
3.2 cm
410 g
Shipping Weight
1.27 kg
Warranties (4)
DZTJ HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only In Stock £24.71
DZTJ HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years In Stock £48.26
DZTJ HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment In Stock £36.49
DZTJ HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year In Stock £18.70
Other bundles (3)
DZTJ HPE DisplayPort DVI-D Adapter In Stock £19.78
DZTJ HPE DisplayPort to VGA Adapter In Stock £13.15
DZTJ HPE USB to Serial Port Adapter In Stock £13.88
