HP t420 Thin Client 2GB 16GB Windows Embedded Standard 7E
Quicklinx: C976WS00 Mfr#: M5R75AT#ABU
Do more with the HP t420 Thin Client, an affordable cloud computing solution that delivers trustworthy reliability and easy deployment and use.
  • Create an all-in-one workspace
    Simplify your HP Thin Client Windows Embedded user experience with HP Easy Shell's customized interface and protection for targeted cloud control.
  • Quick connectivity
    Pick the network connection technology that's best for you with Gigabit Ethernet and support for 802.11n Wi-Fi.
  • Designed with the environment in mind
    Reduce power consumption and help lower your costs with an energy-efficient design.
  • Connect and collaborate
    Enjoy your everyday Microsoft Lync productivity tools.
  • Keyboard and mouse included
    Get right to work with the business-class USB keyboard and mouse.
  • Pick your OS
    Select HP ThinPro for full-featured Linux or HP Smart Zero Technology for simple management.
HP t420 - compact desktop - GX-209JA 1 GHz - 2 GB - flash 16 GB
Thin client - compact desktop - rubber feet
1 x AMD GX-209JA 1 GHz (Dual-Core)
RAM
2 GB (installed) / 2 GB (max) - DDR3L SDRAM
Hard Drive
Flash 16 GB
Optical Storage
No optical drive
1GbE
OS Provided
Microsoft Windows Embedded Standard 7E 32-bit
18 cm x 14 cm x 3.5 cm
740 g
Manufacturer Selling Program
HP Smart Buy
Thin client
Product Form Factor
Compact desktop
Processor / Chipset
CPU
AMD GX-209JA
Clock Speed
1 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
RAM
Installed Size
2 GB / 2 GB (max)
DDR3L SDRAM
Effective Memory Speed
1066 MHz
Low-voltage
Configuration Features
Provided memory is soldered
Hard Drive
Flash
1 x 16 GB
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA, DVI
Max Monitors Supported
2
Wake on LAN (WoL), DHCP support, PXE support
4 x USB 2.0 (2 front, 2 rear) , 1 x DVI-D , 1 x VGA , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet)
Rubber feet
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
HP Smart Buy
Power adapter
Power Provided
45 Watt
Operating System / Software
OS Provided
Microsoft Windows Embedded Standard 7E 32-bit English
18 cm
14 cm
3.5 cm
740 g
