HP T3M80AA 24er LCD Monitor 23.8" 1920 x 1080 VGA HDMI
Quicklinx: CQ2BWS00 Mfr#: T3M80AA#ABU
Our thinnest LCD display yet has a sleek design that's easy on the eyes. And the crisp, vibrant view from almost any angle comes at an ultra-affordable price.
Pushing the limits of thin in an eye-catching design. With our innovative use of high-strength, lightweight metal, we've created our thinnest LCD display yet.
Stunning from edge-to-edge
With ultra-wide viewing angles and vivid 1920 x 1080 resolution, this edge-to-edge display delivers an expansive entertainment experience for seamless multiple display setups.
True-to-life color
When the colors on your display are indistinguishable from real life, the result is a beautifully vivid picture. With Technicolor Color Certification, color accuracy is assured every time.
  • Our thinnest LCD display yet
  • Stunning from edge-to-edge
  • True-to-life color
HP 24er - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
Natural silver, blizzard white
53.98 cm x 18.35 cm x 40.88 cm
3.04 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
CSA, VCCI, C-Tick, BSMI, ISO 9241, NOM, SABS, SASO, CB, CCC, PSB, CSA NRTL/C, FCC, IEC 60950-1, KCC, Energy-using Products (EuP) Lot 6, ICES, S Mark, MEPS, TUV Bauart, E-Standby, KC, CEL, EAC, ISC, GEMS, Energy-using Products (EuP) Lot 5, IS 1121
1-year warranty
Display Type
Energy Class
Class A
28 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Anti-glare, On-screen Digital Controls, Technicolour Colour certified, Mercury free, arsenic-free glass
53.98 cm x 18.35 cm x 40.88 cm - with stand
3.04 kg
VGA , HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+25
1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
19 W
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption (Off Mode)
0.12 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
Without stand - width: 53.98 cm - depth: 3.57 cm - height: 32.29 cm - weight: 2.65 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 1 year
5 °C
35 °C
20 - 80%
