HP T310 Zero Client, TERA2321 PCoIP processor, 512MB, 1920x1200 resolution
Quicklinx: 8BZPWS00 Mfr#: C3G80AA#ABU
VMware's new best friend. Tailor made for VMware environments, the HP t310 Zero Client delivers amazing processing power with the latest PCoIP technology. Gain a seamless desktop experience, even with extensive multimedia. Reduce costs and free up desk space, while increasing security. With no moving parts, reliability is part of its DNA. Get to work fast with impressive boot and response times.
  • The perfect fit
    Get a fanless design and quiet thermals that support mass installments in small spaces plus a 23-inch diagonal screen that puts all your work front and center.
  • The whole package
    Be ready to go out of the box with an included keyboard and mouse.
  • Make it yours
    Customize your all-in-one with an array of inputs that support external peripherals, a second display, Ethernet, and audiovisual interactivity.
  • Technology designed for VMware
    Accelerate your hardware performance with Tera 2 PCoIP and the Teradici Tera 2321 processor.
  • Virtually risk-free
    Help protect your data and software by leaving it on the server, and your device with an optional HP Cable Lock.
  • One world
    Deploy the same configuration around the world with a Global Series SKU that ensures the same product everywhere you do business.
HP t310 - DTS Tera2321 - 512 MB - flash 256 MB
Zero client - desktop slimline - PC over IP (PCoIP) technology
1 x Teradici Tera2321
RAM
512 MB DDR3 SDRAM
Hard Drive
Flash 256 MB
Optical Storage
No optical drive
Audio Output
Stereo - integrated
GigE
OS Provided
HP Smart Zero Client Service
15.2 cm x 13.31 cm x 4.7 cm
630 g
Limited warranty - 3 years
Zero client
Recommended Use
Small business, corporate business
Product Form Factor
Desktop slimline
Processor / Chipset
CPU
Teradici Tera2321
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
RAM
Installed Size
512 MB
DDR3 SDRAM
Hard Drive
Flash
256 MB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
DVI
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
96 kHz
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
Optical
USB
Integrated
Wake on LAN (WoL), DHCP support
4 x USB 2.0 (2 front, 2 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 1 x DVI-I , 1 x audio line-out
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VCCI, EN 61000-3-2, EN55022, ICES-003, ZH1 618, EN 61000-3-3, EN55024, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07
Power adapter
Power Provided
36 Watt
Operating System / Software
OS Provided
15.2 cm
13.31 cm
4.7 cm
630 g
10 °C
35 °C
10 - 90% (non-condensing)
