Speed through workloads with the HP t310 G2 Zero Client. Our best performing zero client has the high performance you want and the security you need. Plus, deployment and management are simple, getting all your devices up and running quickly.
Enhanced ports and graphic options
Upgrade your graphics options with one 1 DVI port and one added DisplayPort , plus a total of 6 USB ports for all of your accessory add-ons. -
Easily connect to a VDI or cloud server
The HP t310 G2 Zero Client easily connects to VDI or cloud servers, including VMWare and Amazon Workspaces environments. -
New look and feel
The t310 G2 Zero Client has a new look and feel and now includes built in VESA mounting pattern. -
Simplified Management
Manage your Zero Client and keep it up-to-date with PCoIP Management Console. A one-year subscription to Desktop Access is included with the purchase of every new HP t310 Zero Client.
- HP t310 G2 - DTS Tera2321 - 512 MB - flash 32 GB
- Zero client - DTS
- Localisation
- Processor
- 1 x Teradici Tera2321
- RAM
- 512 MB DDR3 SDRAM - PC3-10600
- Hard Drive
- Flash 32 GB - multi-level cell (MLC)
- Optical Storage
- No optical drive
- Audio Output
- Stereo
- Networking
- 1GbE, PCoIP
- Power
- (50/60 Hz)
- OS Provided
- No operating system
- 18.72 cm x 13.75 cm x 6.5 cm
- 600 g
- Limited warranty - parts and labour - 3 years
- Zero client
- Product Form Factor
- DTS
- Localisation
Processor / Chipset
- CPU
- Teradici Tera2321
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
RAM
- Installed Size
- 512 MB
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
Hard Drive
- Flash
- Capacity
- 1 x 32 GB
- Multi-level cell (MLC)
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Interfaces
- DVI, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, PCoIP
- Wake on LAN (WoL), DHCP support
- 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (4 front, 2 rear) , 1 x LAN (Gigabit Ethernet) (SFP) , 1 x DVI-I , 1 x DisplayPort
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- VCCI, EN 61000-3-2, EN55022, ICES-003, ZH1 618, EN 61000-3-3, EN55024, RoHS, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, AES-128, WEEE, AES-256, EK1-ITB2000, EN 29241-3, cUL No.60950-1-07
- Power adapter
- Voltage Required
- AC 100-240 V (50/60 Hz)
- Power Provided
- 36 Watt
Operating System / Software
- OS Provided
- Dimensions & Weight Details
- 18.72 cm - 13.75 cm - 6.5 cm - 600 g - with base , 18.5 cm - 13.75 cm - 3.16 cm - without base
- 18.72 cm
- 13.75 cm
- 6.5 cm
- 600 g
- Shipping Weight
- 2.4 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
Warranties (6)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only | In Stock | £24.71 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years | In Stock | £48.26 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment | In Stock | £36.49 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year | In Stock | £18.70 |
HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site | In Stock | £32.96 |
Monitors (2)
HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £491.31 |
HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor | In Stock | £160.87 |
Other bundles (2)
HPE DisplayPort DVI-D Adapter | In Stock | £19.74 |
HPE DisplayPort to VGA Adapter | In Stock | £13.12 |
