HP t310 G2 - DTS Tera2321 - 512 MB - flash 32 GB
Quicklinx: GKZGWS00 Mfr#: 2EZ55AA#ABU
Speed through workloads with the HP t310 G2 Zero Client. Our best performing zero client has the high performance you want and the security you need. Plus, deployment and management are simple, getting all your devices up and running quickly.
  • Enhanced ports and graphic options
    Upgrade your graphics options with one 1 DVI port and one added DisplayPort , plus a total of 6 USB ports for all of your accessory add-ons.
  • Easily connect to a VDI or cloud server
    The HP t310 G2 Zero Client easily connects to VDI or cloud servers, including VMWare and Amazon Workspaces environments.
  • New look and feel
    The t310 G2 Zero Client has a new look and feel and now includes built in VESA mounting pattern.
  • Simplified Management
    Manage your Zero Client and keep it up-to-date with PCoIP Management Console. A one-year subscription to Desktop Access is included with the purchase of every new HP t310 Zero Client.
Zero client - DTS
1 x Teradici Tera2321
RAM
512 MB DDR3 SDRAM - PC3-10600
Hard Drive
Flash 32 GB - multi-level cell (MLC)
Optical Storage
No optical drive
Audio Output
Stereo
1GbE, PCoIP
(50/60 Hz)
OS Provided
No operating system
18.72 cm x 13.75 cm x 6.5 cm
600 g
Limited warranty - parts and labour - 3 years
Zero client
Product Form Factor
DTS
Processor / Chipset
CPU
Teradici Tera2321
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
RAM
Installed Size
512 MB
DDR3 SDRAM
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
Hard Drive
Flash
1 x 32 GB
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
DVI, DisplayPort
Max Monitors Supported
2
Audio Output
Sound Output Mode
Stereo
Ethernet, Fast Ethernet, Gigabit Ethernet, PCoIP
Wake on LAN (WoL), DHCP support
1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (4 front, 2 rear) , 1 x LAN (Gigabit Ethernet) (SFP) , 1 x DVI-I , 1 x DisplayPort
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
VCCI, EN 61000-3-2, EN55022, ICES-003, ZH1 618, EN 61000-3-3, EN55024, RoHS, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, AES-128, WEEE, AES-256, EK1-ITB2000, EN 29241-3, cUL No.60950-1-07
Power adapter
AC 100-240 V (50/60 Hz)
Power Provided
36 Watt
Operating System / Software
OS Provided
No operating system
Dimensions & Weight Details
18.72 cm - 13.75 cm - 6.5 cm - 600 g - with base , 18.5 cm - 13.75 cm - 3.16 cm - without base
18.72 cm
13.75 cm
6.5 cm
600 g
Shipping Weight
2.4 kg
10 - 90% (non-condensing)
Warranties (6)
GKZG HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only In Stock £24.71
GKZG HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years In Stock £48.26
GKZG HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 4 Years Shipment In Stock £36.49
GKZG HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 1 Year In Stock £18.70
GKZG HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £32.96
Monitors (2)
GKZG HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £491.31
GKZG HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £165.42
