Upgrade classroom learning with the thin, light, and powerful HP Stream 11 Pro. Take learning to another level, while maximizing collaboration using stable and reliable connectivity.
Ready to work
From the start of class to after-school homework, stay productive with the Stream 11 Pro's long battery life. -
Budget friendly, classroom ready
This budget friendly notebook is built for learning with WLAN for easy connectivity in the classroom, hardware and firmware TPM for security, fast boot-up time, and 5th Gen Intel Celeron processing power. -
Sleek style, quiet operation
The ultra-slim quiet fan-less design helps keep classrooms focused without the ambient noise from multiple machines. -
Extra security
The embedded Trusted Platform Module 2.0 (TPM) provides hardware-based encryption keys to help secure data, e-mail, and login credentials.
- HP Stream Pro Laptop 11 G3 - 11.6" - Intel Celeron - N3060 - 4 GB RAM - 64 GB eMMC - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit - English
- Processor
- Intel Celeron N3060 / 1.6 GHz, up to 2.48 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 64 GB eMMC
- Display
- 11.6" WLED 1366 x 768 / HD
- Graphics
- Intel HD Graphics 400
- Input Device
- ClickPad
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 2-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 30 cm x 20.56 cm x 1.8 cm
- 1.17 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.48 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
Storage
- Main Storage
- 64 GB eMMC
Display
- 11.6" - TN
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - VGA
- Video Resolutions
- 640 x 480
- Frame Rate
- 24 frames per second
- Camera Features
- Noise reduction
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC3227
- High Definition Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Multi-touch clickpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
- Dual stream (2x2)
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 2-cell lithium polymer
- Capacity
- 37.69 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB 2.0 , USB 3.0 , HDMI
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- HP Support Assistant, HP ePrint, McAfee LiveSafe, McAfee Checkbox, HP JumpStart
- Black
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 1.17 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
