HP STORAGEWORKS DAT72 TV INT DRIV
Quicklinx: 3XQCWS00 Mfr#: AE374AT
Protect your small or medium-sized business, remote office or workgroup with HP DAT Tape Drives offering the ability to store up to 160 GB of compressed data on a single cartridge at speeds of up to 49.3 GB/hr (assuming 2:1 data compression). Low ongoing cost of ownership is provided through low-cost, durable DAT media and backward compatibility which delivers a seamless upgrade path from older drives. HP DAT Tape Drives are now onlt available with 160 GB of capacity with interface types, SCSI, SAS and USB, making them compatible with virtually any server environment. DAT Tape Drives come complete with data and cleaning cartridge, the option to download Yosemite Server Backup Basic backup and recovery software (for a single Windows or Linux server), and HP Library and Tape Tools.
  • High Performance Backup Solution That Fits Most Environments
    Provides a balance of price and performance for small and medium business environments and enterprise workgroups. HP DAT 160 Tape Drives can store up to 160 GB on a single cartridge, backing up to 49.3 GB/hr on a single DAT 160 cartridge in around four hours.Available as external or internal models to fit servers, workstations, and rack-mount kits. SAS, SCSI or USB 2.0 interfaces for universal plug and play.Visit us on the web for the latest information on HP Backup Compatibility.Helps prevent unauthorized access of tape media (lost or stolen cartridges). Tape drive based encryption avoids performance degradation associated with host based encryption.
  • Reduce Your Backup Costs
    Low-cost is driven by low-cost durable DAT media, and ongoing low-cost of ownership.As the most popular backup technology of all time, DAT provides investment protection through a proven track record of reliability and backwards compatibility.
  • Complete Backup Solution
    Restores your entire ProLiant system at the touch of a button without the need for system disks or software CDs. Visit HP One-Button Disaster Recovery (OBDR) Solution for the latest information.Provides a complete, easy-to-use backup solution that includes DAT media, cleaning cartridge, and the option to download Yosemite Server Backup Basic Software, to allow users to protect their data without any additional purchases.
HPE StorageWorks DAT 72 Internal Tape Drive - tape drive - DAT - SCSI
Tape drive
Recording Standard
DAT-72
Enclosure Type
Internal
Interface Type
SCSI
15 cm x 15.8 cm x 4.1 cm
1 kg
Carbon
Storage Removable
DAT - 5.25" x 1/2H
Storage Removable Capacity
36 GB (native) / 72 GB (compressed)
Supported Tape Cartridges (Read and Write)
DDS-3, DDS-4
Data Transfer Rate (native)
3.2 MBps (11.3 GBph)
Data Transfer Rate (compressed)
6.4 MBps (22.5 GBph)
IBM AIX, SGI Irix, SunSoft Solaris, HP-UX, SunSoft Solaris x86, Linux, Red Hat Linux, Microsoft Windows
Microsoft Certification
Compatible with Windows 7
3-year warranty
Tape drive - DAT
Recording Standard
DAT-72
Enclosure Type
Internal
Interface Type
SCSI
Enclosure Colour
Carbon
15 cm
15.8 cm
4.1 cm
1 kg
Storage Removable
DAT - 5.25" x 1/2H
DDS-3, DDS-4
Recording Standard
DDS-3, DDS-4, DAT 72, DDS-5
Average Seek / Access Time
68 sec
Buffer Size
8 MB
1 x Ultra160 SCSI - 68 pin HD D-Sub (HD-68)
Compatible Bay
1 x front accessible - 5.25" x 1/2H
Media Included Qty
5
Cleaning cartridge
MTBF
125,000 hour(s)
TUV, VCCI, C-Tick, BSMI, RRL, CSA 22.2 No. 950, FCC
Software Included
Drivers & Utilities, HP StorageWorks Library and Tape Tools
Limited warranty - parts - 3 years - response time: next business day , Technical support - phone consulting - 3 years
5 °C
20 - 80%
