The sleek, precision-crafted HP Spectre Pro x360 offers the benefits of flexible 360 degree hinge movement and four operating modes. Stay productive with long battery life on an x360 business convertible with 6th Gen Intel Core i5/i7 processors and optional vPro .
- Windows 10 Pro 64
- Intel® Core™ i5-6200U processor
- 33.8 cm (13.3") diagonal Quad-HD touch screen (2560 x 1440)
- 8 GB RAM and 256 GB SATA SSD
Break from the conventional with 360 degree flexibility
Sturdy lightweight aluminum creates a seamless look on this incredibly thin (.61 in. / 15.4 mm.) convertible PC. Starting at just 3.2lbs / 1.45kg, easily switch between four different user modes on the 33.8 cm (13.3") diagonal touch FHD or QHD touchscreen.
Power for hours
Never slow down with long battery life that allows you to create, stay productive, and entertain without having to recharge.
Premium performance
Take charge of your workday with Windows 10 Pro and powerful 6th Gen Intel® Core™ processors with optional vPro™ technology.
Field ready
Never fear bumps and minor spills. The thin and light HP Spectre Pro x360 is designed to undergo MIL-STD 810G testing.
Featuring
Let nothing stand in your way
The best features of your favorite Windows OS and new features come together in Windows 10 Pro.
Take HD up a notch
Lifelike Full HD with an optional QHD ultra-resolution 33,8 cm (13.3") touch diagonal display.
Flexible productivity
Get through your busy day using a notebook and simply fold the 33.8 cm (13.3") diagonal screen over to go between tablet, stand or tent mode and stay connected on the go.
Help secure critical data
Encrypt your SED or SSD drive with Windows BitLocker and TPM 2.0.
Cloud-based IT management made simple
Manage data, security, and devices from a single cloud-based solution with HP Touchpoint Manager.
Road ready
Work in more places with multiple connectivity options to help you stay connected on-the-go.
One smart pen
Help improve productivity with the optional HP Executive Tablet Pen.
Break from the conventional with 360o flexibility
Sturdy lightweight aluminum creates a seamless look on this incredibly thin (.61 in. / 15.4 mm.) convertible PC. Starting at just 3.2lbs / 1.45kg, easily switch between four different user modes on the 33,8 cm (13.3") diagonal touch FHD or QHD touchscreen. -
Power for hours
Never slow down with long battery life that allows you to create, stay productive, and entertain without having to recharge. -
Premium performance
Take charge of your workday with Windows 10 Pro and powerful 6th Gen Intel Core processors with optional vPro technology. -
Field ready
- HP Spectre Pro x360 G2 - 13.3" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Ultrabook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 13.3" WLED touchscreen 2560 x 1440 / WQHD
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- 32.5 cm x 21.8 cm x 1.54 cm
- 1.44 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Enhanced SpeedStep technology, Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s
Display
- 13.3"
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 2560 x 1440 (WQHD)
- Widescreen
- Panel Self Refresh (PSR), QHD ultra wide-viewing angle (UWVA) BrightView eDP
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Camera Features
- HP TrueVision FHD
- Sound
- Stereo speakers, stereo microphone
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 56 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- 3 x USB 3.0 , Mini DisplayPort , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Youcam, Adobe Shockwave Player, HP ePrint, Absolute Data Protect, Foxit PhantomPDF Express, Intel Wireless Display, HP Wireless Hotspot, HP Touchpoint Manager, MS BitLocker, CyberLink Power Media Player 12
- Security
- Intel Anti-Theft Technology (iAT)
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC
- Localization
- 1.44 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
