Feed your notebook with controlled servings of electricity. HP's new 65W Smart AC Adapter regulates power and offsets electrical spikes, is designed to reduce cable stress, and includes a special dongle to support current and prior HP models – perfect for replacing your notebook's power adapter or as a needed back-up.
- HP Smart AC Adapter - power adapter - 65 Watt
- Power adapter - external
- 280 g
- Localisation
- English / United Kingdom
- Output Voltage
- 18.5 V
- Power Capacity
- 65 Watt
- Output connectors
- 1 x power DC jack 4.5 mm
- Included Accessories
- 4.5mm to 7.4mm power DC dongle
- 10.6 cm x 4.7 cm x 2.8 cm
- Localisation
- Input Voltage Range
- AC 90 - 265 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- 18.5 V
- Power Capacity
- 65 Watt
- Cables Included
- Power cable , Power connector adaptor
- Over voltage protection
- CSA, UL, C-Tick, BSMI, GOST, cUL, GS, NOM, SABS, CCC, EMC, PSB, SII, PSE Mark, S Mark, KC, ISC
- 5 °C
- 35 °C
- 10.6 cm
- 4.7 cm
- 2.8 cm
- 280 g
- Shipping Weight
- 0.6 kg
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
H8Z4 051186 Condition: Not in original packaging. Used in good condition |
£11.73 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
