HP Slice Audio Module
Reduced Price - Whilst Stocks Last!
Clearance
Last Few Remaining
Limited Time Offer
Price Drop
Quicklinx: CD8GWS00 Mfr#: X8U72AA
Type: 3 speakers
Stock Status: Clearance
Hurry, only 1 left in stock!
£34.56 ex VAT
£41.47 inc VAT
Express delivery Delivered on Tuesday
Hardware compatibility
HP Elite Slice and HP Elite Slice for Meetings
Convert your HP Elite Slice into a speakerphone or a multimedia player with the HP Audio Module. Meetings, video, and music come to life with impeccable sound and clarity, custom-tuned in collaboration with audio experts at Bang & Olufsen.
Pitch perfect
Experience 360o immersive stereo sound and collaborate from across the room with bi-directional HP Noise Cancellation, a dual-microphone array with far-field 5-meter range, three speakers, and HP Audio Boost.
No cabling or screws required
Snap the Module beneath your HP Elite Slice with a sturdy USB-type connection that provides a simple and clean solution with no messy cables.
Complete, compact collaboration
Focus on your meeting instead of unsightly cables when you combine your HP Elite Slice with the HP Audio Module and the touch-enabled HP Collaboration Cover—each perfect piece designed to fit the other.
Lock it down
Securing your solution is simpler than ever with an integrated universal lock slot that allows you to lock your Module and HP Elite Slice together with one cable lock.
Mix and match
Create a unique solution for each of your employees when you use the HP Audio Module stacked with your HP Elite Slice and any of the other HP Elite Slice accessories.
  • Pitch perfect
    Experience 360° immersive sound and whole room collaboration with a Module that is optimized for use with Cortana and has bi-directional HP Noise Cancellation, dual-mic array with 5m range, 3 speakers, and HP Audio Boost.
  • No cabling or screws required
  • Complete, compact collaboration
    Focus on your meeting instead of unsightly cables when you combine your HP Elite Slice with the HP Audio Module and the touch-enabled HP Collaboration Cover-each perfect piece designed to fit the other.
  • Lock it down
  • Mix and match
HP Audio Module - speaker - for PC
Speaker - for PC
2 microphones
System Components
3 speakers
Speaker Type
Active
Amplifier
Integrated
Speaker System Details
2
Speaker Details
Speaker - stereo - active
Black sparkle
16.5 cm x 16.5 cm x 2.45 cm
404 g
1-year warranty
Elite Slice, Slice for Meeting Rooms; ENVY 750-478nz, 750-537cb, 750-545xt, 750-567cb; ENVY Curved 34-b000ng, 34-b004la, 34-b010nl, 34-b013nf, 34-b071ns, 34-b080nl; Pavilion 24-b017c, 27-a002la, 27-a021, 27-a031
Speaker - for PC
2 microphones
Enclosure Colour
Black sparkle
Speaker System
System Components
3 speakers
Speaker Type
Active
Amplifier
Integrated
Speakers Included
2 - wired
Speaker Details
16.5 cm
16.5 cm
2.45 cm
404 g
Limited warranty - 1 year
HP Elite Slice, Slice for Meeting Rooms , HP ENVY 750-478nz, 750-537cb, 750-545xt, 750-567cb , HP ENVY Curved 34-b000ng, 34-b004la, 34-b010nl, 34-b013nf, 34-b071ns, 34-b080nl , HP Pavilion 24-b017c, 27-a002la, 27-a021, 27-a031
Type: 3 speakers
Brand: HP
Price Range Ex VAT: 0 - 50
