The HP Single Monitor Arm is the perfect desk accessory for your work life. Sleek and streamlined, the HP Single Monitor Arm is designed to complement the way you work.
- HP Single Monitor Arm mounting kit - for LCD display - jack black
- Product Type
- Mounting kit
- Mounting Components
- Desk clamp mount, grommet mount, single-screen mounting arm
- Adjustments
- Tilt
- Recommended Use
- LCD display
- Recommended Display Size
- Up to 24"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 9.1 kg
- Jack black
- Designed For
- HP 100, 34, 6300, Elite 8300, L2105, LA1905, LA2006, LA22, LA2206, LA2306, LE19, LE1901, t430, t430 v2, ZR22, ZR24; EliteDesk 705 G3, 705 G4, 705 G5; EliteOne 705 G2, 800 G1, 800 G2, 800 G3, 800 G5, 800 G6, 800 G8; ProDesk 400 G3, 400 G5, 600 G4; ProOne 400 G2, 400 G3, 400 G4, 600 G1, 600 G2, 600 G3
- Jack black
AV Furniture
- Mounting kit
- Recommended Use
- LCD display
- Up to 24"
- Adjustments
- Tilt
- Max Load Weight
- 9.1 kg
- Adjustable height
- Designed For
- Compaq LA2405wg , HP 100B, 34, L2105tm Touchscreen, LA1905wg, LE1851w, LE1901w, LE1901wm, LE2001w, LE2001wm, LE2201w, LP2065, LP2275w, LP2475w, t430, t430 v2, ZR22w, ZR24w , HP EliteDesk 705 G3, 705 G4, 705 G5 , HP EliteOne 705 G2, 800 G1, 800 G1 Retail System, 800 G2, 800 G3, 800 G5, 800 G6, 800 G8 , HP ProDesk 400 G3, 400 G5 (mini desktop), 600 G4 , HP ProOne 400 G2, 400 G3, 400 G4, 600 G1, 600 G2, 600 G3 , HP Compaq 6300 Pro PC, Elite 8300 PC, L2105tm, LA1751g, LA1905wg, LA1951G, LA2006x, LA2205wg, LA2206x, LA22f, LA2306x, LA2405wg, LE1711, LE1901wl, LE1911, LE19f
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.77 |
